As long as they both reside in the same working directory. Download both work sheets, open only the "Genfit Algo Include Test". The plot is there in < 1 sec. More genfit models are expected. At any point in a work sheet, same topo to read more user algos. Genfit Algo Include.sm (14kb) downloaded 44 time(s). Genfit Algo Include Test.sm (17kb) downloaded 41 time(s).Jean
Everything works great, if you remove "C:\" from include - otherwise it doesn't look at the same directory, but directly at c:\. |
Best regards, Mike Kaganski |
Originally Posted by: уни βNlin() redefined (βNlin() := include() = 4). Light bulb went off with this comment I think these would be cleaner Jean. You can put it in any directory. Genfit Algo Include Test.sm (20kb) downloaded 41 time(s).The directory change in this one is the critical one if I understand it correctly. Genfit Algo Include.sm (15kb) downloaded 40 time(s).
Sure you can put it in any directory, I have only one C: for reasons of hyperfunctionality. Why should I need zillions of directories if one is enough. Smath is not like rabbits and wolfes in the same barn. Afer all, Santa has only one carriage.
Originally Posted by: Jean Giraud Why should I need zillions of directories if one is enough. My files are set up by projects. Edited by user 19 April 2016 15:55:31(UTC)
