#1 Posted : 01 June 2016 17:59:22(UTC)
Was thanked: 983 time(s) in 811 post(s)
... the boiing range has been refactored [given in °K]
Inst_Viscosity Water.sm (51kb) downloaded 76 time(s).
Offline ElSid
#2 Posted : 01 June 2016 18:54:08(UTC)
ElSid
United States
Is this supposed to take over 5 minutes to calculate? May be SMath as this is the second sheet today that "locks-up" with the calculation tool bas and the timer running
#3 Posted : 01 June 2016 20:19:46(UTC)
Originally Posted by: ElSid Go to Quoted Post
Is this supposed to take over 5 minutes to calculate?May be SMath as this is the second sheet today that "locks-up" with the calculation tool bas and the timer running[/quote
Re-download in case something got wrong in the transmission.
XP Home, 1.8 GHz, Smath 5346 OFFicial release => 5 seconds
Inst_Viscosity Water.sm (53kb) downloaded 85 time(s).
Would be interesting more collabs test the timing, thanks.
