In practical Engineering/Modeling, if you have to update 10 parameters individually, like we all do naturally, and if each update takes 10 mn to recalculate the entire work sheet, it's not viable. The autocalc OFF is an option, not so practical either. Some parameters go in pair and it may crash Smath in between individual update. The compactum allows changing all in block, conveniently ... Jean
