Offline Andrey Ivashov
#1 Posted : 19 August 2016 18:05:04(UTC)
Rank: Administration
SMath Studio 0.98.6075 available
Latest changes (against SMath Studio 0.98.6073)
  • SS-2368: Units don't match issue fixed happened in several cases for numeric calculation;
  • SS-2366: Showing of Reference Book and Print Preview windows when SMath Studio shown always on top fixed;
  • Plot Region improved for better support of animated graphs created in previous versions of the program;
  • Fixed issues with repeated worksheet evaluation started automatically without any user request (usually happened on complex worksheet open or on complex expression paste);
  • Symbolic engine: Infinity divided by zero is equal to Infinity now (the same as done for Numeric engine);
  • Location of breakpoints corrected on vertical scrollbar when breakpoint(s) set on operands;
  • Displaying current stop when calculation paused corrected when stop is on operand;
  • Empty Missing Plugins dialog appeared sometimes on file open fixed;
  • Meaningless message of Missing Plugins dialog about incorrect version of built-in plugins (MathRegion and AreaRegion) on file open removed;
  • Handling of remove Region operation improved (worksheet recalculated if content of focused MathRegion deleted using Backspace);
  • Paste of math expression (not a MathRegion itself) from Clipboard do not initiate immediate worksheet recalculation anymore;
  • Shortcut key added to Toggle Breakpoint context menu item;
  • Interface translation files updated;
  • Refactoring.
Download
Edited by user 20 August 2016 10:45:13(UTC)  | Reason: Not specified
thanks 5 users thanked Andrey Ivashov for this useful post.
on 19/08/2016(UTC),  on 19/08/2016(UTC),  on 19/08/2016(UTC),  on 19/08/2016(UTC),  on 19/08/2016(UTC)
Offline RFreund
#2 Posted : 20 August 2016 04:02:32(UTC)
RFreund
United States
What does this refer to:
"Shortcut key added to Toggle Breakpoint context menu item"
Thanks!
#3 Posted : 20 August 2016 10:46:17(UTC)
Sure. Screenshot added above.
Offline RFreund
#4 Posted : 20 August 2016 18:26:00(UTC)
RFreund
United States
Thank you. Good
One other thing I've noticed. When using equal sign to display the result of an equation or variable, I usually want to change the units. I used to hit the right arrow three times and it would bring me to the new units "blank space". Now I have to arrow through all the decimals in order to get there. Was this an intended change?
#5 Posted : 20 August 2016 18:40:21(UTC)
You're welcome.
Nope, seems I just forgot about this behavior during MathRegion code review. Will check it, thank you.
on 20/08/2016(UTC)
Offline mikekaganski
#6 Posted : 20 August 2016 18:47:07(UTC)
mikekaganski
Could it be possible then to go to units placeholder immediately when one inserts equal? What's the reason to stay before it?
Best regards,
Mike Kaganski
thanks 3 users thanked mikekaganski for this useful post.
on 20/08/2016(UTC),  on 20/08/2016(UTC),  on 21/08/2016(UTC)
