Offline Peter J Francis
#1 Posted : 01 August 2017 13:43:27(UTC)
Peter J Francis
United Kingdom
Hi all ,
I'm putting together a sheet using the CoolProp wrapper
It generally works really well except for the following
Where I'm getting strange units for the Specific Heat capacity of Air
I've tried overriding the units but still don't get what I want (J/kg/K)
I've attached an extract from the sheet --> UnitsProblem.sm (8kb) downloaded 36 time(s).
Probably a really simple answer but I can't seem to find it !! Sad
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
#2 Posted : 01 August 2017 15:37:11(UTC)
Was thanked: 745 time(s) in 480 post(s)
Can't reproduce. J/(kg*K) works. Paste 'J/{'kg*'K} to the square placeholder to the right of the unit when the region has focus.
Pre-configured portable distribution of SMath Studio: https://en.smath.info/wi...th%20with%20Plugins.ashx
on 02/08/2017(UTC)
#3 Posted : 01 August 2017 23:05:37(UTC)
Was thanked: 586 time(s) in 454 post(s)
Can't reproduce either "Units don't match",
because there is NO heat capacity unit in Smath.
on 02/08/2017(UTC)
Offline CBG
#4 Posted : 02 August 2017 00:52:12(UTC)
CBG
Was thanked: 34 time(s) in 26 post(s)
You just have to change the units.
thanks 1 user thanked CBG for this useful post.
on 02/08/2017(UTC)
#5 Posted : 02 August 2017 11:28:04(UTC)
Peter J Francis
United Kingdom
Thanks All,
You are all correct (I knew the answer was going to be obvious ) , pasting in the units J/kg K works fine
Its just that Gy/K seems an odd default unit
Thanks for your help
Peter
Peter J Francis
Offline ioncube
#6 Posted : 04 December 2017 22:09:32(UTC)
ioncube
Rank: Member
Pakistan
hey fellows, how do I calculate WET steam properties through this extension,lets suppose at 16Bar Pressure & 0.7 quality 7 which IFP standard is currently being used?
#7 Posted : 05 December 2017 16:27:10(UTC)
Originally Posted by: ioncube Go to Quoted Post
how do I calculate WET steam properties through this extension,lets suppose at [b]16Bar Pressure
Good question. The vapor phase is dry and properties don't change.
That portion of water that drags at the bottom of piping must be
taken into account for massflow calculation.
At the speed steam flows, better be dry. If not => will destroy
my control valves. Puzzling question ?
Offline ioncube
#8 Posted : 05 December 2017 17:17:30(UTC)
ioncube
Rank: Member
Pakistan
The property(s) that does change when you add water to steam is NOT its pressure or temperature but its enthalpy ...the most major parameter which defines the amount of work that can be extracted
Yes wet steam at very high velocities can be micro bullets for control valves & turbine blades causing erosion
#9 Posted : 05 December 2017 18:00:21(UTC)
Worst than erosion => cavitation.
Can't help more. Steam out of the balloon is dry, isn't ?
If you have wet steam out of the balloon, you have a serious level control problem.
