Hello to all here. I have done nothing (beside normal yum updates) but suddenly, smath for mono is no longer working: Mono version is mono --version Mono JIT compiler version 4.6.2 (Stable 4.6.2.16/ac9e222 Mon Jul 31 05:33:23 UTC 2017) Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com TLS: __thread SIGSEGV: altstack Notifications: epoll Architecture: amd64 Disabled: none Misc: softdebug LLVM: supported, not enabled. GC: sgen The output is a bit longer, so I have attached a file For searching here the final error: ================================================================= Got a SIGSEGV while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= .. smath_mono_startup_error.txt (7kb) downloaded 13 time(s).Does anyone know the solution? Greeting, Holger PP: shot time, the problem seems to be obsolet, but now i have it again.... Edited by user 24 September 2017 02:28:09(UTC)
