Might not be the place for this, but I see no button in the bugs area to add a post. I'm not a developer or programmer, so forgive me for asking a question. downloaded Writer region files, and put them in the plugins folder. [unless I missed them, there are no instructions with the download as to where to put them] When I bring up Smath, I get the following error Assuming the pic didn't upload, the error says this: "The following plug ins cannot be started. Please update or remove them, otherwise plug ins will be automatically disabled" WriterRegion.dll GUID;34001943-fc64-4578-9c39-330263ca0424 Method'get_MenuItems' in type "WriterRegion.WriterImplementer'frmo assembly etc. There aren't any instructions with the download as to where to put the files, so I assume I put them in the right place. My install of Smath is only a couple of days old.
Hello
nlinesk8s
, Originally Posted by: nlinesk8s Might not be the place for this, but I see no button in the bugs area to add a post.I'm not a developer or programmer, so forgive me for asking a question. It is one of the correct places, don't worry Originally Posted by: nlinesk8s downloaded Writer region files, and put them in the plugins folder. [unless I missed them, there are no instructions with the download as to where to put them] The expected procedure to install the plug-ins is through the built-in extensions manager (launch SMath Studio, and go to Tools > Plugins... > Online Gallery (top-right button)); please remove any file you have created manually and try in this way. About manual install (that should be avoided if not strictly required): - Plugins folder in the installation directory is just for built-in plug-ins;
- downloaded plug-ins are stored in %APPDATA%\SMath\extensions\plugins\{PLUGIN_GUID}\{PLUGIN_VERSION}; next to this folder a config.{SMATH_VERSION}.ini file contains infos about which version of the plugin should be loaded and if it is enabled/disabled
For specific questions about this plugin in particular (and documentation too) you can look in the dedicated topic. Edited by user 20 September 2017 19:02:59(UTC)
thanks! That worked. I came to the plugin via a websearch, and it only had a download link. If I had come through the wiki, it clearly showed how to do this; my bad.
Good... marked as solved. |
