SMath Studio Forum
Bugs & Problems
Strange rounding issues for small custom units
I implemented several units to deal with field unit conversions for oil field calculations.
In the oil field we use strange units:
millidarcies (mD), centipoise (cP), and barrels/day,
the other units have largely already been implemented by smath: wheee!.
mD is an absurdly small unit which I defined as:
<property dimension="253"> <add factor="4.0468564224" exp="3" system="Imperial" id="295"> <synonym name="acre" lang:rus="акр" /> </add>
<add factor="9.869233" exp="-13" system="Imperial" id="441"> <synonym name="D Darcy" /> <extension for="D"> <prefix name="m" /> </extension> </add>
where 295 is <add connection="m^2" id="253" />
which I hope is alright.
if I make a statement, like
k:=20'mD
"and then query k,
I get results that seem to round to 1 decimal place, ie
2*10^-14 m^2
ohh my goodness that is ~1.5%, which is poor performance compared to all the other awesome features!!
it seems to do this in decimal mode, and not in fraction mode, which sort of makes sense, that the fractions would not be rounded the same way.
Seems like a wierd floating point error.
also the behavior isn't always reproducible. very strange.
thanks for the awesome program!
Originally Posted by: Jean Giraud ... many more Engineering don't come as easily as 2*3=6 m² You don't have to freak Smath unit system, just like this: ... rather like this
SMath Studio Forum
Bugs & Problems
