5 Pages<1234>»
Online uni
#21 Posted : 24 August 2013 16:37:51(UTC)
uni
Originally Posted by: uni Go to Quoted Post
Updated. Now the installer is located within the plugin.
There is an user interaction issue. After updating the plugin and re-starting smath,
the installer dialog pops up and offers installation. You are also informed that you do not need installation if you already have the runtime environment installed. In this case it is natural that the user chooses [Cancel]. Then, however, the dialog pops up every time you launch smath.
If you choose [Install] even if you know that nothing needs to be installed, then suddenly the installer gets aware of that and just finishes and no more messages appear on start-up.
Updated. I think I found a way to do the installation without the use of environment variable path. You can remove the path from the environment variable. Also, you can delete the installation files from c:\MATLAB6p5.
Russia ☭ forever
Viacheslav N. Mezentsev
on 24/08/2013(UTC)
#22 Posted : 24 August 2013 17:24:53(UTC)
Works here.
Is there a chance to return scalars if the result matrix has 1x1 size by default (without touching each function separately)? Then we could use all the functions as direct replacement for the standard ones. The drawback would be that these functions cannot handle lists (except if you can recognize that in the plugin and do sys2mat and vice versa.
One could even think of working with any nested structures by flattening them out internally and afterwards restructuring the results according to input.
I guess that unit handling would not be trivial. However, for most special functions this is irrelevant anyways.
Online uni
#23 Posted : 24 August 2013 18:36:32(UTC)
uni
Works here.
Updated. Done. As for the rest, I'll think about it.
Russia ☭ forever
on 24/08/2013(UTC),  on 25/08/2013(UTC)
#24 Posted : 24 August 2013 19:17:01(UTC)
Great! Thanks a lot. Now all functions can be called with scalar argument and return scalars in that case. Is it sensible to include the mw... names in the doc (some of them are already in it) or can they be expected to change to generic ones in the near future?
Online uni
#25 Posted : 24 August 2013 19:27:08(UTC)
uni
I'm not sure, but I think that next year we will not see support for namespaces and function overloading. Andrey is a very busy. Therefore, I recommend to use prefixes in the documentation.
For now we have 49 functions.
Russia ☭ forever
on 25/08/2013(UTC),  on 25/08/2013(UTC),  on 25/08/2013(UTC)
#26 Posted : 25 August 2013 00:16:12(UTC)
Thanks for the information. If the loss of list processing capability would be the only drawback of just re-defining the internal functions, I would vote for that.
Something went wrong with the diagonal scaling. I can't see such a function.
Offline omorr
#27 Posted : 25 August 2013 11:32:19(UTC)
omorr
Rank: Administration
Serbia
Thank you uni Good
As I could see in the first post of yours, when you manage to get those functions to work you are updating the plugin - blue starting with mw... (I counted more than 49 at the moment )Good and the rest in some green - not working yet. By the way, an insignificant observation about - on ode function in the list, mw... prefix is missing.
If you get most of those functions in the list to work in spite of the mentioned obstacles in SMath (different number of arguments etc.), it would be really something big Victory .
on 25/08/2013(UTC)
#28 Posted : 25 August 2013 12:38:43(UTC)
The functions mwall() and mwany() do not work correctly.
Also, I recommend to modify the calling syntax.
mwany(M) test if any of the elements in M is nonzero. Corresponds to matlab any(M( : )), where the colon operator flattens the matrix into a vector.
mwany(M,1) or mwany(M,2) do the test along the columns and rows respectively (no change except bug fixing required)
Same for mwall.
Edited by user 25 August 2013 12:40:35(UTC)  | Reason: Not specified
File Attachment(s):
mwall.sm (11kb) downloaded 59 time(s).
mwany.sm (11kb) downloaded 53 time(s).
Online uni
#29 Posted : 25 August 2013 13:04:51(UTC)
uni
Updated. 83 functions (see log.txt in the plugin folder).
Russia ☭ forever
Offline omorr
#30 Posted : 25 August 2013 14:16:02(UTC)
omorr
Serbia
Thank you uni Good
I tried it first and could see that mwbesselx() functions do not work. Then I checked the log.txt file.
This is the end of it
8/25/2013 12:35:58 PM [INFO ] [Plugin.Initialize()] Successfully. 83 functions loaded.
8/25/2013 12:39:34 PM [ERROR] [Plugin.NumericEvaluation()] mwbesseli(2) Exception has been thrown by the target of an invocation.
8/25/2013 12:39:51 PM [ERROR] [Plugin.NumericEvaluation()] mwbesseli(2) Exception has been thrown by the target of an invocation.
8/25/2013 12:39:56 PM [ERROR] [Plugin.NumericEvaluation()] mwbesseli(2) Exception has been thrown by the target of an invocation.
8/25/2013 12:41:32 PM [ERROR] [Plugin.NumericEvaluation()] mwbesseli(2) Exception has been thrown by the target of an invocation.
8/25/2013 12:41:50 PM [ERROR] [Plugin.NumericEvaluation()] mwbesseli(2) Exception has been thrown by the target of an invocation.
No success with mwbetainc() yet as well. I suppose you know all this, just wanted to confirm.
Online uni
#31 Posted : 25 August 2013 14:35:46(UTC)
uni
Show me log.txt from the \bin\win32\ directory.
Russia ☭ forever
#32 Posted : 25 August 2013 15:29:05(UTC)
I confirm the problem. The log in bin/win32 says
25.08.2013 14:18:54 [ERROR] [mwbesseli] Failed to load MEX-File : besselmx.
25.08.2013 14:19:00 [ERROR] [mwbesseli] Failed to load MEX-File : besselmx.
25.08.2013 14:19:09 [ERROR] [mwbesselj] Failed to load MEX-File : besselmx.
25.08.2013 14:19:16 [ERROR] [mwbesselj] Failed to load MEX-File : besselmx.
25.08.2013 14:19:20 [ERROR] [mwbesselj] Failed to load MEX-File : besselmx.
25.08.2013 14:20:55 [ERROR] [mwbesseli] Failed to load MEX-File : besselmx.
and I get an error message from SMath (translated)
The program cannot be launched because DFORMD.dll is missing on your computer. Re-install the program to solve the problem.
such a dll is present on my system as part of the ANSYS finite element package.
on 25/08/2013(UTC)
Offline omorr
#33 Posted : 25 August 2013 16:00:05(UTC)
omorr
Serbia
I checked the log.txt file. There is only one message repeating when I call any of the bessel functions
8/25/2013 2:22:55 PM [ERROR] [mwbesseli] Failed to load MEX-File : besselmx.
when I try to use mwbetainc() there is only one message about the first argument
8/25/2013 2:45:00 PM [ERROR] [mwbetainc] X must be in the interval [0,1].
although I used something like this
z:range(0,10)
mwbetainc(0.5,z,3)=#@#
with the usual error message ...-function is not defined
[EDIT] I do not have a message about missing dll like Martin
Edited by user 25 August 2013 16:03:10(UTC)  | Reason: Not specified
on 25/08/2013(UTC)
Online uni
#34 Posted : 25 August 2013 16:13:29(UTC)
uni
Updated. Try now. As for mwbetainc(), I don't know yet what's going on.
Russia ☭ forever
on 25/08/2013(UTC)
Offline omorr
#35 Posted : 25 August 2013 16:21:39(UTC)
omorr
Serbia
I can confirm that mwbesselx() functions are working for me Good . Thank you.
Edited by user 25 August 2013 16:24:13(UTC)  | Reason: Not specified
on 26/08/2013(UTC)
Online uni
#36 Posted : 26 August 2013 12:37:51(UTC)
uni
Updated. 112 functions.
Added: mwrand(), mwrandn(), mwsize(), mwconv(), mwconv2(), mwnnz(), mwnonzeos(), mwtrace(), mwconj(), mwxor(), mwtril(), mwtriu(), mwcorrcoef(), mweye(), mwones(), mwzeros(), mwroots(), mwrot90(), mwsum().
Russia ☭ forever
on 26/08/2013(UTC),  on 26/08/2013(UTC)
#37 Posted : 26 August 2013 16:45:32(UTC)
I am trying to keep up... ;-)
When you assign a matrix generating function to a variable, then this is done symbolically by default in your plugin. Thus, a random matrix looks differently every time it is used. This behaviour is different from Davide's Statistical tools, where numeric evaluation seems to be default.
I guess that symbols with changing contents at every use are somewhat unexpected for the user. Therefore, I would therefore recommend to set evaluation to numeric by default, unless there is something to gain from symbolic evaluation (which I do not see so far, bit I may be wrong).
Edit: There are multiple implications of that SMath symbolics is unaware of scalar or vector properties of operands. Therefore I urgently recommend to suppress symbolic evaluation for (possibly) matrix valued functions. In the second example, replacing mwones() by Ones() solves the problem (mismatch between symbolic and numeric evaluation)
Edit2: To internally apply eval() in every function should help.
Edited by user 26 August 2013 18:06:15(UTC)  | Reason: Not specified
on 27/08/2013(UTC)
#38 Posted : 27 August 2013 00:57:17(UTC)
some functions do not work...
Error message in log file: Argument to xxx must not be complex.
Error message in SMath: function is not defined.
I can't see any complex argument.
File Attachment(s):
Section math boolean matlab.sm (26kb) downloaded 54 time(s).
on 27/08/2013(UTC)
Offline omorr
#39 Posted : 27 August 2013 08:00:14(UTC)
omorr
Serbia
Confirmed
log.txt from the plugin folder
the last part
8/27/2013 6:50:53 AM [INFO ] [Plugin.Initialize()] Successfully. 112 functions loaded.
8/27/2013 6:52:42 AM [ERROR] [Plugin.NumericEvaluation()] mwxor(2) Exception has been thrown by the target of an invocation.
8/27/2013 6:52:55 AM [ERROR] [Plugin.NumericEvaluation()] mwxor(2) Exception has been thrown by the target of an invocation.
8/27/2013 6:53:08 AM [ERROR] [Plugin.NumericEvaluation()] mwand(2) Exception has been thrown by the target of an invocation.
8/27/2013 6:53:13 AM [ERROR] [Plugin.NumericEvaluation()] mwxor(2) Exception has been thrown by the target of an invocation.
8/27/2013 6:53:13 AM [ERROR] [Plugin.NumericEvaluation()] mwand(2) Exception has been thrown by the target of an invocation.
8/27/2013 6:53:19 AM [ERROR] [Plugin.NumericEvaluation()] mwxor(2) Exception has been thrown by the target of an invocation.
8/27/2013 6:53:48 AM [ERROR] [Plugin.NumericEvaluation()] mwor(2) Exception has been thrown by the target of an invocation.
log.txt from win32 folder
8/27/2013 6:52:42 AM [ERROR] [mwxor] Operands to AND must not be complex.
8/27/2013 6:52:55 AM [ERROR] [mwxor] Operands to AND must not be complex.
8/27/2013 6:53:08 AM [ERROR] [mwand] Operands to AND must not be complex.
8/27/2013 6:53:13 AM [ERROR] [mwxor] Operands to AND must not be complex.
8/27/2013 6:53:13 AM [ERROR] [mwand] Operands to AND must not be complex.
8/27/2013 6:53:19 AM [ERROR] [mwxor] Operands to AND must not be complex.
8/27/2013 6:53:48 AM [ERROR] [mwor] Operands to OR must not be complex.
on 27/08/2013(UTC)
Online uni
#40 Posted : 27 August 2013 12:09:24(UTC)
uni
Updated. 136 functions.
mwrand(), mvrandn(), mwand(), mwor(), mwnot(), mwxor() - bugs fixed;
As for symbolic simplifications when dealing with matrices, I think that in this case it's a bug. The multiplication operator believes that the second operand returns a scalar, but this is not true.
uni attached the following image(s):
Russia ☭ forever
on 27/08/2013(UTC)
5 Pages<1234>»
