SMath Studio Forum
Bugs & Problems
[DEV] Custom Regions: issues / requests / ideas
issues found in Custom Regions: Code:public override void ToXml(XmlTextWriter writer, FileParsingContext parsingContext)
the parsingContext.FileName is empty Code:public ovverride void OnMouseMove(MouseEventArgs e)
OnMouseMove can't recognize that the mouse goes outside the region when you move fast the pointer (mouse jumps out from the region and the coordinates are not updated) (already) requested features (no rush): - a way to customize region's borders (as idea a simple color control could be enough - switching the color to white or transparent one can draw customized borders inside the region - the default border color can be restored on region focus to show the standard resize layout); - a way to hide resize's placeholders; ideas: - not sure if this is possible/easy to make: a way to add and handle an undefined number of variables' placeholders to place freely inside the region (this maybe with a way to disable the main placeholder) best regards, Davide Edited by user 03 February 2014 21:11:45(UTC)
Originally Posted by: w3b5urf3r_reloaded
ideas:
- not sure if there is already a "standard way" to do this: a region to make "shapeshifter" functions ( i mean functions like sum(), el() , line(), sqrt(), etc... )
best regards,
Davide
I strongly support both proposals: - Multiple placeholders would be fine for axis limits and x and y expressions in diagrams (mathcad-like)
- see image for proposals of custom operator formats (from "wish list.sm" in the Activebook).
mkraska attached the following image(s): |
Another little issue (or is a feature?) Code:IPluginCustomRegion.TagName
is used to get the regions from the worksheet, but the tag name on the worksheet seems is set using the class/namespace name... |
SMath Studio Forum
Bugs & Problems
