3 Pages<123>
#21 Posted : 25 September 2013 21:04:55(UTC)
Was thanked: 1125 time(s) in 722 post(s)
Originally Posted by: w3b5urf3r_reloaded Go to Quoted Post
I can do it, but are you sure? if you want just to resize the region and you go outside the placeholders, the region will resize (just to ask, I agree with the "less things as possible" approach)...
OK, then how about double-click?
If you can resize by mouse action all over the region, why do you need the placeholders? Resizing just by dragging any point inside would be easier than to point at the tiny markers...
BTW, if the image is displayed using an image region (by uni), then the image export is silently blocked for the rest of the session, even if the image region is removed afterwards. This might as well happen if other software has the images open. Thus I would recommend to issue an error message if export fails (if that can be checked).
#22 Posted : 25 September 2013 22:25:08(UTC)
Double click seems a good solution, at least as idea... I don't know if the image region causes issues.... Btw export reports are available in the bottom left corner of smath
on 25/09/2013(UTC)
#23 Posted : 25 September 2013 23:05:41(UTC)
Cool.
BTW: The region is not Ctrl-drag-proof.
Edited by user 25 September 2013 23:11:38(UTC)  | Reason: Not specified
#24 Posted : 25 September 2013 23:38:17(UTC)
What's the issue with ctrl+drag?
Offline kilele
#25 Posted : 25 September 2013 23:55:40(UTC)
kilele
what is supposed to do ctrl+drag ? something wrong happens to me with this key combination: after a ctr+drag one more frame is created, see the problem in this video. I'm using the unofficial portable version.
http://screencast-o-matic.com/watch/cIQTrhVm8V
Edited by user 26 September 2013 00:16:54(UTC)  | Reason: Not specified
#26 Posted : 25 September 2013 23:56:00(UTC)
Sorry for being unspecific, see attachment. To relieve you have to press continue and then ESC to drop the copy operation.
#27 Posted : 26 September 2013 00:47:45(UTC)
Originally Posted by: kilele Go to Quoted Post
done see the post above
mhhh... Isn't the same behavior of other regions? Unsure
Found & Fixed, thank you Good
on 26/09/2013(UTC)
#28 Posted : 26 September 2013 01:27:57(UTC)
Handbook page for Snapshot region added.
@kilele: your video shows, that you are writing a snapshot doc as well, is that right? If so, how about a bit of co-ordination? I really do not insist on documenting everything myself and would be happy to integrate contributions to the activebook (can be done via SVN). There is plenty of white spots, a lot of work yet to do...
File Attachment(s):
Plugin Snapshot Region.sm (46kb) downloaded 45 time(s).
#29 Posted : 26 September 2013 01:30:42(UTC)
Is my plugin reference's sheet, I'll send you a link Good
Offline kilele
#30 Posted : 26 September 2013 01:44:18(UTC)
kilele
sorry for the confusion, didn't know what ctr+drag was for, now I can see that the region can be dragged around without problems
thanks 1 user thanked kilele for this useful post.
on 26/09/2013(UTC)
#31 Posted : 13 October 2013 00:17:28(UTC)
I'd propose to write the export files with white background instead of translucent. Perhaps this might be an option. The problem shown in the attached image could also be solved by the image region providing white background. But that would not be entirely equivalent, because the Image region is currently unaware of the image dimensions.
#32 Posted : 13 October 2013 05:19:48(UTC)
That's an image region feature, the exported PNGs are not transparents (try yourself opening the images with an image editor)
Offline uni
#33 Posted : 13 October 2013 08:04:34(UTC)
uni
Yes, Davide is right, I make image transparent, removing the white background.
Russia ☭ forever
Viacheslav N. Mezentsev
on 13/10/2013(UTC)
#34 Posted : 15 October 2013 12:22:10(UTC)
UPDATED
- version 1.0.* (password is no more required);
- Double-click over the region to make the region compact/fullsize;
- Added Spanish translations (thanks to kilele);
- Fixed Italian and German translations (thanks to Martin Kraska);
- Fixed crashes due to wrong handling of exceptions' propagations;
- minor changes.
Edited by user 15 October 2013 12:56:03(UTC)  | Reason: Not specified
#35 Posted : 19 December 2013 23:44:12(UTC)
UPDATED
- Added "copy to clipboard"
edit: documentation & translation sheet updated (look at the first post)
Edited by user 23 December 2013 01:28:59(UTC)  | Reason: Not specified
on 20/12/2013(UTC)
#36 Posted : 24 January 2014 12:05:01(UTC)
If a file with Snapshot regions is opened and then saved at a different location, the default snapshot save path still points to the location of the original file. I propose to change this such that default save location is always the directory where the SMath sheet resides.
#37 Posted : 24 January 2014 14:49:00(UTC)
I've updated the plugin. The file needs to be refreshed after the save in the new location to have the path updated (bug alredy reported)
#38 Posted : 03 February 2014 21:03:03(UTC)
UPDATED
- SMath Studio 0.96.5146 required
- German translation updated with latest strings
best regards,
Davide
#39 Posted : 13 February 2014 02:18:06(UTC)
UPDATED
- Paste as SMath string temporary disabled (this let you paste strings on the canvas freely)
#40 Posted : 08 March 2014 21:48:44(UTC)
I experience an "insufficient memory" error when exporting "all" snapshots in the attached sheet. It is possible to recover from the error message. Individual export works.
File Attachment(s):
Bedienelemente.sm (5kb) downloaded 43 time(s).
Guest (2)
3 Pages<123>
