Hello, Here are some tests with Equation Systems. There might be a bug with some functions calling? Regards, Radovan |
I can confirm problem with "working for real" numbers (middle portion) as per the attached example. It appears that the real value is not being carried over. If I individually type in the real number, then it works sin(5.3)=-.8323
