2 Pages12>
#1 Posted : 24 November 2013 17:05:24(UTC)
Glyphs for functions Beta
  • requirements: SMath Studio 0.97.5737 or later (previous versions may have different features);
  • installation: SMath Studio: Tools > Plugins... > Online Gallery;
  • documentation: CustomGlyphs.sm (6kb) downloaded 61 time(s). CustomGyphs.pdf (32kb) downloaded 73 time(s).;
  • sources: SVN repository.
>>> PLEASE REPORT IN THIS THREAD ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
For older versions of SMath (prior to 0.97.5737) the password is: test
Documentation for those old versions is attached below:
Edited by user 31 May 2016 10:28:03(UTC)  | Reason: Not specified
File Attachment(s):
FunctionsExtension_examples.sm (55kb) downloaded 150 time(s).
thanks 3 users thanked Davide Carpi for this useful post.
on 24/11/2013(UTC),  on 24/11/2013(UTC),  on 24/11/2013(UTC)
Offline omorr
#2 Posted : 24 November 2013 18:59:05(UTC)
omorr
Rank: Administration
Serbia
Many thanks Davide Good
I would mentioned once more that having so many functions from the growing number of plugins becomes more and more problematic in tracking them out (I just can imagine how problematic should be for Martin to keep up in making the Handbook up to date). The number of Function Categories should be increased because it is the first instance (Besides the Dynamic Assistance) when you can see what function you can use for the specific problem.
PS. By the way Davide, what happened with ICDF.t(), ICDF.ChiSquare() and ICDF.F() from Statistical Tools plugin? Fortunately, we can use distrib package in Maxima Good
PSS. Once more to note the possible problem when frequantly installing/updating plugins from the Gallery (see the picture). If this happened, the only way is to delete the extension folder, and to install all the plugins again - AFAIK
Edited by user 24 November 2013 19:11:54(UTC)  | Reason: Not specified
omorr attached the following image(s):
#3 Posted : 24 November 2013 19:36:23(UTC)
Davide, thanks for the update.
There is still quite something to do until we can symbolically integrate functions involving your operators. Maxima can do that only if the cases expand to sign() and abs() or possibly unitstep(). Perhaps we also could split the integrals appropriately at the interval limits and send the individual functions to Maxima.
The at() operator currently can handle just very special types of expressions. We could map it to the at() function in Maxima, see attachment. We did so with the det() function in the recent update (announcement to come)
How about posting an example in the Maxima topic of the Samples subforum? Maybe, there are still usability issues which we could fix...
Normally it is sufficient to delete the most recently installed plugins. Usually I have to delete the Maxima and the TableRegion directories.
File Attachment(s):
at.sm (8kb) downloaded 68 time(s).
#4 Posted : 24 November 2013 22:27:30(UTC)
I know, maybe the Viacheslav proposal about namespaces will help...
I'm looking for numerical approximations Wallbash, if someone knows about some resources to use Umnik ...
I've never experimented the error in your screenshot, in the other hand the plugin updates sometimes (2 times, as for now) causes me workspace's "red cross of death" scrolling up and down worksheets Crazy ...
I see, I don't know how to fix this (because anyway I'm expecting the use of booleans in the conditions - see the screenshots)
I'd like to add a function to make working at(2) and at(3) (indipendently from the Maxima plugin), let me know what I can do...
Edited by user 24 November 2013 22:30:38(UTC)  | Reason: Not specified
on 24/11/2013(UTC)
#5 Posted : 24 November 2013 23:00:08(UTC)
Maxima can integrate piecewise continuous functions, if they do not contain boolean expressions. Fortunately, there are workarounds for that. If you redefine the cases() functions in a similar way as a<x<b, then integration (definite and indefinite) should be possible.
#6 Posted : 24 November 2013 23:16:02(UTC)
I miss something... why this doesn't work?
#7 Posted : 24 November 2013 23:58:42(UTC)
Handling of boolean expressions is quite different between Maxima and SMath. The way I proposed is inspired by how Derive (R.I.P.) simplified piecewise functions 20 years ago.
You could use abs() instead of sign(), that might work as well.
From the maxima manual:
The symbols < <= >= and > represent less than, less than or equal, greater than or equal, and greater than, respectively. The names of these operators are "<" "<=" ">=" and ">", which may appear where the name of a function or operator is required.
These relational operators are all binary operators; constructs such as a < b < c are not recognized by Maxima.
Relational expressions are evaluated to Boolean values by the functions is, maybe, if, while, unless. They are not otherwise evaluated or simplified to Boolean values, although the arguments of relational expressions are evaluated (when evaluation is not otherwise prevented by quotation).
Maxima(is(1<2))=true@#
I do not understand the expression sign(abs(x>0)). if x>0, then the boolean expression returns 1, otherwise 0. abs() does not change that, neither does sign().
In SMath you can replace a<b by 0,5(1+sign(b-a)), which is not entirely the same, the difference is in how the case a=b is handled. For integration purposes, however, that does not matter.
#8 Posted : 25 November 2013 02:07:21(UTC)
Okay, the problem is that cases output conditions and statements without preprocessing, so there are booleans... Maxima can't add (as general rule) an is() when there are boolean operators, or, if this is not possible, overriding the cases function?
The sign(abs(#)) was to reproduce the actual behavior of the symbolic cases(), that use any 0 value as 'false' and any not null value as 'true' (mainly to skip the preprocessing of the conditions and to avoid scaling factors)
Edited by user 25 November 2013 02:38:14(UTC)  | Reason: Not specified
Offline omorr
#9 Posted : 25 November 2013 03:40:15(UTC)
omorr
Serbia
Done
Offline omorr
#10 Posted : 25 November 2013 03:50:27(UTC)
omorr
Serbia
Davide, I would really like to help - but simply do not know how what is a common programming way of these functions in order to avoid the problematic numerical issues Sad .
#11 Posted : 11 December 2013 04:10:16(UTC)
UPDATED
- at(2) and at(3) now are working functions
features:
* implicit equivalence needs a value for each variable, sorted alphabetically;
* with explicit equivalence (variable == value) the replacement could be limited to some unknowns or extended to anyone.
[edit] 1st post documentation updated
Edited by user 11 December 2013 22:00:10(UTC)  | Reason: Not specified
File Attachment(s):
at.sm (18kb) downloaded 59 time(s).
on 11/12/2013(UTC),  on 11/12/2013(UTC),  on 14/12/2013(UTC)
#12 Posted : 15 December 2013 19:05:51(UTC)
How about this one:
Offline experimentator
#13 Posted : 10 March 2014 16:04:55(UTC)
experimentator
Rank: Member
Spain
I can't work out how the function 'cases' works.
experimentator attached the following image(s):
Learning by doing
#14 Posted : 10 March 2014 16:16:02(UTC)
Just add some argument separators (, or Wink until you see some magic. Add more separators to get more lines. Take care, you cannot remove lines.
#15 Posted : 10 March 2014 16:46:04(UTC)
experimentator
Rank: Member
Spain
Danke nochmals. Many thanks, so easy...
Learning by doing
#16 Posted : 08 May 2014 00:47:12(UTC)
I've never used MathCad but looking the continuous posts the evaluation through vector elements seems like a drug Laugh wild
So I've planned to add something similar in this plugin; here's a screenshot of the undressed working function... I'm looking for a name, I've thinked to do(2) (because is fast to write - but this may be used hereafter for a do statement?) or maybe each(2)... if anyone has some better ideas about the name... Cool
Best regards,
Davide
Edited by user 08 May 2014 01:25:34(UTC)  | Reason: Not specified
on 08/05/2014(UTC),  on 08/05/2014(UTC),  on 08/05/2014(UTC)
Offline omorr
#17 Posted : 08 May 2014 11:37:00(UTC)
omorr
Serbia
Maybe foreach(2) if it is not too long Good
#18 Posted : 08 May 2014 12:33:25(UTC)
Davide, thanks for approaching this challenge. I see two different issues:
1. mapping functions or expressions to structures by element vec(expr)
- identify the variables in expression (without preprocessing
- get variable values (structures) from context
- iterate over the elements replacing the element values for the structure variable names in expr and building a result of the same structure as the variables.
This would require the variables in expression to be either of the same structure or scalars. You might relax that condition to variables being of identical length, if linear adressing is unique and well defined. Then you would return a vector of corresponding length.
I think, the right over-arrow just like in Mathcad would be appropriate, even if I'd rather like arrows, overbars or the like to be available as decorations for variable names.
This is essentally what your function do() does already, except that perhaps the function could find out by itself, which variable to iterate over.
2. Implicit loops to generate matrix or vector results. Input is the index equation or it's parts (result name, expression, index names). I failed to provide a working example, the definitions might illustrate, what I mean.
apply(res,expr,i1,i2):line(expr1:at(expr,sys(i1≡ii1,i2≡ii2,2,1)),for(ii1,i1,for(ii2,i2,el(res,ii1,ii2):expr1)),res,3,1)
apply(res,expr,i1,i2):line(ii1:i1,ii2:i2,for(i1,ii1,for(i2,ii2,el(res,i1,i2):expr)),res,4,1)
The input
el(M,i,j):i+j
would be translated to
apply(M,i+j,i,j)
But that would require your function decorating to cover both sides of an assignment.
The names in my examples are arbitrary, I would stick, however to something like vectorize(), vector() or vec(), as this would be consistent with Mathcad speech and with the decoration symbol.
Edited by user 08 May 2014 12:37:55(UTC)  | Reason: Not specified
#19 Posted : 09 May 2014 00:26:22(UTC)
unfortunately this is a popular statement too, like do/while... Good
The input
el(M,i,j):i+j
apply(M,i+j,i,j)
The function was thinked to handle functions with scalar single unknown; I think could be extendeded to other cases using (implicitly) at(2) when there are more than a single unknown, limiting the evaluation at the first nesting level (or maybe not, looking from the deepest level and going up, but this is another step...). As for the "dress" I don't like a LHS+RHS approach, because in this case it would seem an assignment instead of a function (and if you place a function on the canvas without an evaluation, nothing happens); as first approach I've thinked to a modified version of at(2) or el(2), with some bracket [#] <#> or symbol @# near the subscript (BTW apply is not a bad idea...).
Edited by user 09 May 2014 01:13:11(UTC)  | Reason: Not specified
#20 Posted : 09 May 2014 02:09:38(UTC)
I'd propose to limit special formatting of functions to those cases that have a chance of being understood by non-SMath-experts or non-programmers. at(), cases() or the ternary comparisons are very good examples of this approach. That's why the range variables are that popular, because most engineers would understand the index equations.
How would you write your do() functions on paper? That might then inspire the "dressing".
on 09/05/2014(UTC)
Guest (2)
2 Pages12>
