Offline RFreund
#1 Posted : 05 March 2014 20:03:29(UTC)
RFreund
United States
I can't quite figure out the set of circumstances which apply when this happens but I seem to lose the bottom portion of a calculation when I save or maybe when I close out of a document. I'm not sure where the "split" occurs but the document does contain multiple separators, images and areas.
I am using Smath Travel version so I'm not sure if it applies to both. The travel version is stored on dropbox and so is the saved document.
If I go back in the previous versions saved on dropbox it appears that this happens if you insert an Area then delete the top line of the area and leave the bottom line. I must have done this accidentally but none the less it seems you lose all the data below the bottom area line.
Is this correct? or maybe there is something else going on.
Thanks,
Ryan
thanks 2 users thanked RFreund for this useful post.
on 05/03/2014(UTC),  on 18/03/2014(UTC)
#2 Posted : 17 March 2014 02:14:49(UTC)
Was thanked: 1332 time(s) in 876 post(s)
Original post by RFreund here
Originally Posted by: RFreund Go to Quoted Post
I seem to lose the bottom portion of a calculation when I save or maybe when I close out of a document. I'm not sure where the "split" occurs but the document does contain multiple separators, images and areas. [...] if you insert an Area then delete the top line of the area and leave the bottom line. I must have done this accidentally but none the less it seems you lose all the data below the bottom area line.
(reproduced in the attachments)
Best regards,
Davide
[Moderator: uni] it was my fault. I moved and lost messages.
MOVED IN THE BUG TRACKER
Edited by user 22 March 2014 21:18:59(UTC)  | Reason: Not specified
File Attachment(s):
initial file.sm (3kb) downloaded 18 time(s).
end file.sm (2kb) downloaded 18 time(s).
on 17/07/2014(UTC)
Offline RFreund
#3 Posted : 17 July 2014 14:07:16(UTC)
RFreund
United States
I voted for a couple "Area handling" issues in the bug tracker but does anyone know if this one is in the tracker?
I'd like to name this one the kiss of death or maybe "good morning surprise" would be a more accurate description... very easy to miss (not to mention frustrating) if you are dealing with many separators and areas.
#4 Posted : 17 July 2014 14:11:53(UTC)
My fault, I've forget to post the link: SS-2
Best regards,
Davide
on 17/07/2014(UTC)
