Online uni
#1 Posted : 03 May 2014 14:49:29(UTC)
uni
Memo Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
Memo control based on Regions.Control and FastColorerTextBoxCF. Used as an example of the region without a place holder.
Short keys:
Ctrl + A - Select All
Ctrl + C - Copy
Ctrl + V - Paste
Ctrl + X - Cut
Ctrl + U - Upper/Lower Case
Ctrl + Left|Right
Ctrl + Shift + Left|Right
Ctrl + Home
Ctrl + End
Links:
1. Fast Colored TextBox for Syntax Highlighting (Pavel Torgashov).
Edited by user 01 November 2020 00:12:35(UTC)  | Reason: Not specified
uni attached the following image(s):
Russia ☭ forever
Viacheslav N. Mezentsev
on 03/05/2014(UTC),  on 04/05/2014(UTC),  on 16/06/2014(UTC)
#2 Posted : 03 May 2014 15:14:49(UTC)
Is there a chance for a general rtf region which calls an appropriate editor upon double click either in place or in a separate window? That could partly adress SS-47.
Online uni
#3 Posted : 03 May 2014 15:31:49(UTC)
uni
All these editors are based on RichEdit control, which has their own canvas for drawing. We can't use it due to the fact that the components do not support this capability. The only way - do it yourself, like I do it. Another way - wait until Andrey change the input method for the SMath worksheet (he thinks about it).
Other methods will not be portable I think.
Russia ☭ forever
Online uni
#4 Posted : 03 May 2014 19:36:51(UTC)
uni
Updated. Small improvements.
Russia ☭ forever
Online uni
#5 Posted : 16 June 2014 10:22:54(UTC)
uni
Updated.
Russia ☭ forever
on 16/06/2014(UTC)
Online uni
#6 Posted : 16 June 2014 16:50:12(UTC)
uni
Quote:
It reacts at the font size changement but it seems adapted only for font size 10 ?
You can change font with mouse wheel and Control key when region selected.
Quote:
In the source that you had indicated it seems that the fonts and the colors (text and background) can be handled (?).
This is not entirely true. Component has no internal data to store information about the properties of the text. Syntax highlighting is performed on the fly. You can not arbitrarily change the color, etc. The only thing what you can do - create highlighting rules.
Quote:
Is it imaginable to control this propeties in a similar way as in Davide's plugins (buttons, combobox etc.) ?
I need to see this. If you talk about the properties of the text, as I said above can't modify them.
Not everything works as it should.
Short keys:
Ctrl + C - Copy
Ctrl + V - Paste
Ctrl + X - Cut
Ctrl + Left|Right
Ctrl + Home
Ctrl + End
Edited by user 16 June 2014 17:15:31(UTC)  | Reason: Not specified
Russia ☭ forever
on 16/06/2014(UTC)
Online uni
#7 Posted : 18 September 2018 20:53:35(UTC)
uni
Updated. Version 0.2.x.x.
Changes:
- xml serialization format changed;
- reworked.
Old versions of the plugin will not be able to open files of a new format.
Disabled until the better implementation.
Edited by user 18 September 2018 20:56:17(UTC)  | Reason: Not specified
Russia ☭ forever
