16 Pages«<678910>»
#141 Posted : 04 August 2014 16:13:59(UTC)
mhhhh.... Can see just error messages...
on 04/08/2014(UTC)
#142 Posted : 04 August 2014 16:51:39(UTC)
This looks like you have tried the VTK interface in the same Maxima session (SMath instance). In order to revert to gnuplot interface for Draw you might restart Maxima using MaximaControl("restart" ) or open the update message in a virgin SMath instance.
#143 Posted : 04 August 2014 17:20:49(UTC)
Originally Posted by: omorr Go to Quoted Post
Very interesting Good
Of course, it is a bit unstable at the moment. Sometimes strange things happen. The part of the notebook moves into the Draw2D(), Draw3D() region and scrolling is inside that region. SMath crashes then. I can not reproduce this at the moment, sorry.
Thanks, Radovan, filed as SS-188.
#144 Posted : 04 August 2014 17:36:58(UTC)
I've simply opened you attachment (no further SMath instances running)
MaximaControl("restart") doesn't help Sad
I attach the log.
Best regards,
Davide
Edited by user 04 August 2014 17:38:48(UTC)  | Reason: Not specified
File Attachment(s):
Maxima.txt (4kb) downloaded 68 time(s).
#145 Posted : 04 August 2014 18:13:28(UTC)
I attach the log.
Testing was done using the portable distribution (Maxima 5.33.0), updated to the current SMath release candidate.
The log shows that you are using Maxima 5.31.1-1.
Update of the portable distribution is straightforward: Just take the SMath linux tarball and copy it's contents to the install dir of the portable distribution.
#146 Posted : 04 August 2014 19:47:19(UTC)
Ok, tried mixing the desktop SMath with Maxima 5.33 from your SMath package and it works (so the problem is just the Maxima version)
thank you,
Davide
Offline aishen
#147 Posted : 27 August 2014 13:23:37(UTC)
aishen
Rank: Member
France
I am wondering if this maxima example could work on smath maxima ?
http://www.vttoth.com/CM...-computer-algebra-system
#148 Posted : 27 August 2014 21:23:59(UTC)
I just gave it a try, see the result in the attachment. The packages seem to load despite the odd error message, probably due to a output parsing problem in the plugin.
The plugin, however, is not to blame for the failure of the icurvature command. It is correctly translated (had to use capital E in order to avoid translation into %e).
I used recent SMath studio and Maxima 5.33.0 as in the portable distribution.
If tensor stuff with co- and contravariant indices would work, one could think of providing a nice operator form via functions extensions. But it might be hard to tell these indices from ordinary matrix indices, subscipts or just exponents.
File Attachment(s):
example.sm (8kb) downloaded 59 time(s).
Offline aishen
#149 Posted : 30 August 2014 10:16:40(UTC)
aishen
Rank: Member
France
Thanks for trying I run the example and had the same result.
Offline Alex M.
#150 Posted : 22 September 2014 20:22:27(UTC)
Alex M.
Hello, mkraska, got a question for you.
Does current implementation of maxima "Solve" function permit solving of system of equations (linear or non linear)?
If not, what command may I use?
Thank you!
#151 Posted : 22 September 2014 22:09:02(UTC)
Thank you!
Yes, this should normally work. There is an example in the Solve() handbook page, see [?]> Function index> S> Solve()
File Attachment(s):
_Solve.sm (30kb) downloaded 70 time(s).
Offline Alex M.
#152 Posted : 22 September 2014 22:12:28(UTC)
Alex M.
Thank you, did not see that. (btw when I hit "thank you" button here in the forum I get an error).
Offline zapzapouch
#153 Posted : 13 November 2014 20:35:06(UTC)
zapzapouch
Rank: Member
United States
Sorry if this is already covered, but I installed this today and it works but every time I start SMath it stops working and says
Quote:
Cannot find maxima.bat
Cannot find maxima.bat. Do you want to enter a start search path now?
Yes No
in "Path to Maxima" it says "...Program Files (x86)\Maxima-5.30.0\bin\maxima.bat" which is correct.
if I push "Select Folder" and navigate to that same folder again it says Starting Maxima and then
Quote:
Path to Maxima
Found "..\Maxima-5.30.0\bin\maxima.bat".
OK
then if I recalculate the page it works. Then if I restart Smath, it asks for the path again.
Me too.
Edited by user 13 November 2014 20:36:39(UTC)  | Reason: Not specified
#154 Posted : 14 November 2014 01:11:01(UTC)
I recommend to use the pre-configured portable version (see signature)
Offline zapzapouch
#155 Posted : 14 November 2014 02:18:22(UTC)
zapzapouch
Rank: Member
United States
Well I already have Maxima installed, I can't just use the existing installation?
#156 Posted : 14 November 2014 15:02:46(UTC)
I can reproduce the problem. It happens because the settings window sometimes replaces the path to maxima by a relative one (as required for a portable version). For the desktop version this is a bug. Nonetheless you can enforce the correct absolute path to maxima by either correcting the entry in the settings window or by directly editing maxima.xml in the extensions directory structure.
If I remember correctly, Maxima version 5.30.0 had problems with the draw package.
Offline zapzapouch
#157 Posted : 14 November 2014 18:35:55(UTC)
zapzapouch
Rank: Member
United States
Next time I open the settings window it's back to the relative path, though.
Where is that? I can't find it.
They just released maxima-5.34.1 so I'm on that now.
Offline zapzapouch
#158 Posted : 14 November 2014 19:14:52(UTC)
zapzapouch
Rank: Member
United States
Found it.
~\AppData\Roaming\SMath\extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41\maxima.xml
and changed it to:
<PathToMaxima.bat>C:\Program Files (x86)\Maxima-5.34.1\bin\maxima.bat</PathToMaxima.bat>
#159 Posted : 16 November 2014 05:11:54(UTC)
Based on the brand new windows installer for Maxima 5.34.1 the portable distribution has been updated. There are some new features in the draw package which can be used in SMath Studio:
- new option key_pos for placement of the legend
- support of more line styles for svg image format
File Attachment(s):
Update14.sm (398kb) downloaded 83 time(s).
on 16/11/2014(UTC)
Offline PompelmoTell
#160 Posted : 18 April 2015 12:11:22(UTC)
PompelmoTell
I updated Maxima (Maxima: 5.36.0 Lisp: SBCL 1.2.7). The Maxima plugin now does not work.
In fact it is loaded (it appears the loading bar ), but when I run the commands I get the message "Cannot start maxima ...".
Has anyone tried and confirmed?
WIN7 64 bit
SMath Studio Desktop 0.97 build 5581
Guest (3)
Similar Topics
Error implementing ToolboxGroup for the maxima plugin (Questions)
by fakemoses 31/07/2023 20:09:47(UTC)
Maxima Plugin Feedback Survey: Share Your Ideas and Report Bugs (Feature Requests)
by fakemoses 16/06/2023 13:27:33(UTC)
MAXIMA PLUGIN expand (Questions)
by Angel695 21/05/2023 10:43:40(UTC)
Solve Function Stuck (46/47) with Maxima Plugin (Questions)
by Albedo 30/08/2022 05:24:23(UTC)
[Maxima Plugin] Text exportation issue (Questions)
by SteelCat 11/01/2022 12:47:31(UTC)
Maxima Plugin problem (Bugs & Problems)
by FT_PENG 23/12/2021 23:49:19(UTC)
Text characters not passing correctly to Maxima plugin (Bugs & Problems)
by gurro 15/08/2021 00:14:03(UTC)
[Maxima Plugin] is a custom Maxima function call-able in SMath (Questions)
by 007.000 22/05/2018 13:06:49(UTC)
[Maxima Plugin] least common multiple (Questions)
by 007.000 22/05/2018 12:13:20(UTC)
news for Maxima Plugin (Questions)
by oscampo 27/01/2016 18:39:35(UTC)
Maxima plugin error (Bugs & Problems)
by olik 30/11/2015 10:17:28(UTC)
16 Pages«<678910>»
