4 Pages«<234
Offline omorr
#61 Posted : 06 June 2014 22:14:23(UTC)
omorr
Rank: Administration
Serbia
BTW, you also can use ODE.2, a wrapper for ode2, with preprocessing of the equation switched off.
Also, you can specify the initial conditions in Solve using Davide's at().
Thank you, just forgot about it out and found it afterwards.
#62 Posted : 09 June 2014 03:28:13(UTC)
Yet another example from the maxima discussion list. It demonstrates use and limitations of the solver function Solve().
File Attachment(s):
Example Maxima cross.sm (22kb) downloaded 69 time(s).
#63 Posted : 03 August 2014 14:45:44(UTC)
The Maxima draw package has an experimental interface to the VTK visualization toolkit. It provides high performance 3D rendering.
Objects and options are very similar to those of the Gnuplot interface in the commands Draw2D() and Draw3D().
The current state of the Maxima plugin allows you to play around with VTK. Some limitations apply:
- The interactive viewer is opened as a separate window (not embedded in the sheet)
- The Maxima plugin does not wait for the viewer to be closed but gives up after some short time.
- Any SMath action while the viewer is open can generate a crash.
File Attachment(s):
vtk.sm (19kb) downloaded 74 time(s).
on 03/08/2014(UTC)
#64 Posted : 03 August 2014 15:30:13(UTC)
Another example
File Attachment(s):
vtk1.sm (71kb) downloaded 69 time(s).
on 03/08/2014(UTC)
Offline omorr
#65 Posted : 03 August 2014 18:24:12(UTC)
omorr
Serbia
Thank you Martin with keeping this up Good
I just played a bit (see the picture, please). I suppose this will be improved and I wish you all the best of luck in your efforts.
In the case I did not do something wrong here, but it seems that my example produces additional gnuplot windows.
File Attachment(s):
probavtk.sm (6kb) downloaded 61 time(s).
#66 Posted : 04 August 2014 22:53:01(UTC)
This is related to issue SS-189. Maxima is restarted and the plugin retries to execute the command. However, in the new Maxima process, the variable draw_renderer has the default value (gnuplot) instead of VTK.
#67 Posted : 07 August 2014 00:15:17(UTC)
If the image file format is set to png, then the plot functions provide enhanced text capabilities now. See the attachment.
File Attachment(s):
Section Maxima Draw2D3D enhanced.sm (156kb) downloaded 69 time(s).
on 07/08/2014(UTC)
#68 Posted : 26 August 2014 00:25:27(UTC)
Here comes life to the gradient symbol of the functions extensions plugin.
File Attachment(s):
Gradient.sm (29kb) downloaded 62 time(s).
thanks 4 users thanked mkraska for this useful post.
on 26/08/2014(UTC),  on 26/08/2014(UTC),  on 26/08/2014(UTC),  on 29/01/2017(UTC)
#69 Posted : 15 September 2014 16:11:34(UTC)
In the attached sheet you find the construction of the element stiffness matrix and the element load vector for a shear-stiff plane horizontal beam finite element as used in this example.
File Attachment(s):
Balkenelement FEM Herleitung.sm (142kb) downloaded 76 time(s).
on 27/01/2017(UTC)
Offline PompelmoTell
#70 Posted : 05 February 2015 13:54:32(UTC)
PompelmoTell
Example for beam calculation using separate integration intervals.
I tried to use this method on a simple case with triangular distributed load.
I got the correct results for V and M moment but not for w and rotation (file1).
Using the same equations but divided into two separate systems ( equilibrium and elastic line) the result is correct (file 2)
anyone can give me any suggestions?
File Attachment(s):
file1.sm (27kb) downloaded 57 time(s).
file2.sm (28kb) downloaded 54 time(s).
#71 Posted : 18 January 2017 19:00:15(UTC)
This example produces Asby material property charts. The data has been taken from the online ressources for Buchmayr 2002. Besides the Maxima plugin and it's drawing functions this program also demonstrates the use of varous plugins by Davide (ComboBox List, DataExchange, Checkbutton List)
It was posted already 3 years ago, works with the current SMath+Maxima version (no symbolics involved). Just cosmetic changes (output as PNG instead of SVG)
Werkstoffdiagramme.zip (55kb) downloaded 73 time(s).
on 18/01/2017(UTC),  on 18/01/2017(UTC)
Guest (2)
Similar Topics
Maxima application source code (Questions)
by ioan92 18/10/2023 00:14:38(UTC)
Error implementing ToolboxGroup for the maxima plugin (Questions)
by fakemoses 31/07/2023 20:09:47(UTC)
Problems with release of MaximaPlugin (Bugs & Problems)
by mkraska 14/07/2023 12:07:53(UTC)
Maxima Plugin Feedback Survey: Share Your Ideas and Report Bugs (Feature Requests)
by fakemoses 16/06/2023 13:27:33(UTC)
Cannot solve a matrix equation with the Maxima plug-in (Questions)
by EngMath 13/06/2023 12:19:51(UTC)
MAXIMA PLUGIN expand (Questions)
by Angel695 21/05/2023 10:43:40(UTC)
Solve Function Stuck (46/47) with Maxima Plugin (Questions)
by Albedo 30/08/2022 05:24:23(UTC)
Maxima Draw2D labels error (Bugs & Problems)
by DiegoV 14/06/2022 07:52:42(UTC)
I can't access Maxima tools (Bugs & Problems)
by yeyu 19/05/2022 06:48:56(UTC)
The Maxima Solver can't solve the symbolic equations (Questions)
by netsonicyxf 19/02/2022 10:35:04(UTC)
Can't solve linear equation involving temperatures with Maxima plug-in (Questions)
by EngMath 30/01/2022 16:40:45(UTC)
SMath on Linux with Maxima (Questions)
by micky 17/01/2022 19:28:57(UTC)
[Maxima Plugin] Text exportation issue (Questions)
by SteelCat 11/01/2022 12:47:31(UTC)
Maxima Plugin problem (Bugs & Problems)
by FT_PENG 23/12/2021 23:49:19(UTC)
Maxima Draw 2D (Questions)
by PE_Electron 23/12/2021 21:28:05(UTC)
4 Pages«<234
