Joined: 21/08/2014(UTC) Posts: 18 Was thanked: 1 time(s) in 1 post(s)
Re:1;mu:0.1,numer; epsilon:0.001,numer; z:sqrt((mu/epsilon)),numer; %omega:float(sqrt(1/(mu*epsilon))); R:z$freq:[]$H:[]$ for f:2 step 1 thru 100 do (w:2*%pi*f,Zs:R+%i*w*mu-%i/(w*epsilon), Vout:R/Zs,freq:append(freq,[f]), H:append(H,[abs(Vout)]))$ fr 1/(%pi*2*sqrt(mu*epsilon))),numer; wxplot2d([discrete,float(freq),float(H)], [logx],[xlabel,"Fréquence (MHz)"], [ylabel,"Impédance"], [style,[lines,1,11]], [gnuplot_preamble, "unset key; set title 'Fréquence de résonance MHz'"])$
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
The attached file shows two versions, one merely literal translation and one more "paper and pencil" like version. Both versions exploit the still experimental Maxima Draw2D region. Edited by user 04 September 2014 15:41:50(UTC)
| Reason: Not specified File Attachment(s): mkraska attached the following image(s): |
Excellent on window with maxima plugin. As I work on linux I am trying to convert them I can't make resonance plot (f|Vout|) include example Edited by user 05 September 2014 18:43:18(UTC)
