SMath Studio Forum
Questions
Some Snippets Do Not Show in Extensions Manager -> Snippet Window
Why are some files saved in my snippets folder not available to select shen looking in the tools -> snippet manager ? Attached is an example of such file.
You must define a snippet shortcut to have a valid snippet, otherwise is just a smath worksheet in the snippet folder. go to: File > Properties > File Atributes Edited by user 09 January 2015 03:07:23(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
Someday that thank button will work... or not. Thank you!
Your solution works and is better than what I was doing but it is still odd that when you use tools -> Snippet Manager that some files populate while other do not.
SMath Studio Forum
Questions
