hi
if i try to calculate this: 300^1.3 then it gives the result fine. if i try to calculate 300^1.274 then it gives an error: "result is above max allowed positive number"
i tried this with the latest beta release. the previous verson from february calculates it fine.
Hello. This is known problem. The only way to beat it is to use workaround with round(...) function as shown on the screenshot below: This will be fixed later.
If you remember, "eval" function has been introduced in the case of rather complicated symbolic result resulting in slow calculation. If we need the numerical result only, by using "eval" the calculation time can be reduced drastically. Sometimes "eval" will not help. Here is an example were "round" can aslo help . This is an Example from the SMath included Examples. (Numerical instability is expected, of course). Without "round" you can use up to 26-th polynomial degree. Regards, Radovan PS. It is interesting to note that in this particular case "eval" will drastically increase the computational time. It might be usless (very slow) for higher polynomial degree. I do not know why, but "round" will do do job quite good. Forgot to mention - this is from 0.87 stable version. Could someone check it on 0.87 Beta? I will also check it tomorow at my office. Edited by user 14 March 2010 17:19:20(UTC)
hi
thanks. but it worked fine in the 10-february-2010 release. i mean there was no need for using the rounding... i have a calculation sheet that worked fine, but after installing the new beta version yesterday it gave an error. i could attach the file here, but there is no such button.
regards, istvan
Hello Istvan, Yes, you are right. In the 0.87 stable version there would be no error issued. buenos wrote:i have a calculation sheet that worked fine, but after installing the new beta version yesterday it gave an error. i could attach the file here, but there is no such button. You could use some file hosting service or you can make from .sm an archived (.zip) file and upload it on the Wiki (File Management - menu on the right). Then make a link to it here. Regards, Radovan Edited by user 14 March 2010 17:15:39(UTC)
Not sure about next stable release, but this will be fixed in future. For now we have a solution mentioned in my previous comment (it is acceptable for your file as well). Edited by user 14 March 2010 20:40:32(UTC)
buenos wrote:if i try to calculate 300^1.274 then it gives an error: "result is above max allowed positive number" Fixed.
Joined: 10/12/2009(UTC) Posts: 249 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Hi, I was trying:
n:=30000 pf:=1/n pv:=pf*(1-pf)^n
and I obtained the error "result is above max allowed positive number". But, when I select the "pv:=pf*(1-pf)^n" and choose "Calculation/Optimization/Numeric", SMath find the correct answer: "pv=1.226*10^-5". The same happen when you choose "Calculation/Optimization/None"
Oscar
Joined: 29/01/2010(UTC) Posts: 13 Location: Portsmouth UK
oscampo wrote:Hi, I was trying:
Oscar Right click over the definition of pv and select optimisation and set the option to numeric (this is for version 0.88) and all will be well. Note, to very high precision (1-1/3000)^3000=1/e, e being Euler's number and the base of natural logarithms. CB Edited by user 18 April 2010 14:06:53(UTC)
