Welcome Guest! To enable all features please Registers on the forum. New Registrations are disabled.
Offline captainblack
#1 Posted : 13 March 2010 22:27:18(UTC)
captainblack
Rank: Member
Any ideas on what is going on here (it is to check a limit numerically for a question posted on mathhelpforum):
(the limit is exp(-1/3))
CB
Edited by user 13 March 2010 22:33:09(UTC)  | Reason: Not specified
#2 Posted : 13 March 2010 22:40:30(UTC)
captainblack
Rank: Member
Is it because the function definition is not respecting the order of evaluation implied by the brackets?
CB
Offline Andrey Ivashov
#3 Posted : 14 March 2010 08:17:03(UTC)
Rank: Administration
Hello.
This is known problem. The only way to beat it is to use workaround with round(...) function as shown on the screenshot below:
This will be fixed later.
P.S.: The same type of error reported here: x^y=error.
#4 Posted : 14 March 2010 16:42:17(UTC)
captainblack
Rank: Member
smath wrote:
Hello.
Thanks. I think I prefer the other work around from the other thread:
since it forces the order of evaluation.
CB
Edited by user 14 March 2010 16:44:54(UTC)  | Reason: Not specified
#5 Posted : 01 April 2010 06:26:44(UTC)
To fix this I've added new useful option for every Math region, calls "Optimize evaluation".
It is possible now to prevent optimization of the function/variable definitions by symbolic library. Turning off the optimization can cause reducing of the evaluation performance, but it can increase it in some cases too. Also this feature can help to solve some possible issues in the future. See pictures bellow for further explanation:
Figure 1: Document with evaluation error.
Figure 2: Switching off control's optimization.
Figure 3: Document without evaluation error.
Feature will be available with the next SMath Studio release.
Regards.
#6 Posted : 01 April 2010 21:09:51(UTC)
captainblack
Rank: Member
That looks great (it will solve at least one other problem I have been having)Clap
Thanks
CB
Edited by user 01 April 2010 21:11:30(UTC)  | Reason: Not specified
Offline omorr
#7 Posted : 11 April 2010 01:01:14(UTC)
omorr
Serbia
Hello Andrey,
I hope this might fit under this topic.
There is "Explicit" function in SMath present (symbolic result only). I found this by browsing Russian side of the Forum. Moreover, this function is not present neither in the function list nor in the Dynamic assistant list. I am just courious, what would be with it. Are you intending to drop it out maybe?
#8 Posted : 11 April 2010 03:32:37(UTC)
There are several undocumented functions (see three of them on the screenshot). They are not documented because I know some major problems related to them and don't want them to be used in the real worksheets, because they can be excluded from future versions of SMath Studio.
For now these functions can be used as some easter eggs of the program Biggrin
Regards.
Offline omorr
#9 Posted : 11 April 2010 04:23:11(UTC)
omorr
Serbia
I thought the reason might be as axplained.
Thanks anyway Good
