Offline Werner Beek
#1 Posted : 11 June 2015 15:04:25(UTC)
Werner Beek
Netherlands
Dear all,
Daily I'm working on my smath file. Since the latest changes I get the following error while saving:
"Unexpected end of file has occurred. The following elements are not closed: input, math, region, region, region, region, regions. Line 35237, position 18."
The programm closes and the saved file cannot be opened any more. Does anyone know a solution?
Thanking you in advance,
Werner
#2 Posted : 12 June 2015 02:11:39(UTC)
You can (partially) fix the file by closing the missing xml tags (using a text editor).
To find the cause and fix the issue a reproducible sequence of actions or the file is needed (you may contact directly the developper if the file can't be shared here)
on 12/06/2015(UTC)
Offline omorr
#3 Posted : 12 June 2015 10:02:49(UTC)
omorr
Rank: Administration
Serbia
Hello Davide,
Is there any way that someone can write a Recovery script which will fix the broken SMath file. I remember that I found long time ago some similar script for the corrupted Mathcad files.
thanks 2 users thanked omorr for this useful post.
on 12/06/2015(UTC),  on 12/06/2015(UTC)
#4 Posted : 12 June 2015 13:49:13(UTC)
I think is possible. Tomorrow I'll try to do something.
Offline Werner Beek
#5 Posted : 17 June 2015 13:16:14(UTC)
Werner Beek
Netherlands
Dear all,
I installed the latest nightly build version of Smath and since then I cannot reproduce the error any more.
Similar Topics
Crash and error while saving file (Bugs & Problems)
by Macs 13/08/2015 19:14:18(UTC)
