Offline cecile
#1 Posted : 18 November 2014 11:34:54(UTC)
cecile
France
I saved my smath file yesterday after having added a lot of locked regions.
Today I have troubles opening my file : it opens but only displays a very small part of the content...
I have also noticed that it is strangely big (about 70000 Ko).
Someone please help me to recover my file?
Cécile
#2 Posted : 18 November 2014 12:12:44(UTC)
That is a quite challenging task without having the file...
Offline cecile
#3 Posted : 18 November 2014 13:07:42(UTC)
cecile
France
I know, but it's far too big to be uploaded here...
First I can try to send you a version of what is left of my document.
If you cannot do anything with it, maybe I can try to upload it on a drop box?
Thanks for answering anyway...
Cécile
Edited by moderator 19 January 2016 16:41:34(UTC)  | Reason: Not specified
File Attachment(s):
save of what remains.sm (4kb) downloaded 34 time(s).
#4 Posted : 18 November 2014 13:48:22(UTC)
Hello Cécile,
try to zip it, otherwise you can make a folder with your name in the forum_attach folder of the wiki (max 20Mb) or you can use a dropbox link Good
Offline cecile
#5 Posted : 18 November 2014 14:36:29(UTC)
cecile
France
Ok, I have uploaded it here : https://www.dropbox.com/...ttZHgmy4Z5cSLrhLMia?dl=0
Hope something can be done.
Thanks for your time anyway.
Cécile
#6 Posted : 18 November 2014 17:13:12(UTC)
Hi Cécile,
All the data is encrypted inside an area region, so I guess that the only way to attempt to solve your issue is to contact the developer (smath)
Best regards,
Davide
Offline cecile
#7 Posted : 18 November 2014 18:58:08(UTC)
cecile
France
Thanks a lot Davide.
I have managed to find an old file, so I think I will restart from here...
Cécile
Offline brotjob
#8 Posted : 19 November 2014 16:54:23(UTC)
brotjob
Switzerland
Was thanked: 7 time(s) in 7 post(s)
I can open the file and I see one collapsed area. When I try to open the area I am prompted for a password which I don't have.
When I try to open the file again with the Area plugin disabled (trying to recover what is not in an area) I get an error "System out of memory".
I don't get this error when I open the file directly with the disabled plugin.
Anyway, those cases where you loose your data because it is overwritten by a corrupted version are a major reason not to use Smath Studio in a productive environment. Sadly I never had a reproducible case to report but it happened to me several times.
Offline Andrey Ivashov
#9 Posted : 19 November 2014 23:13:19(UTC)
Rank: Administration
Did you experience situations when file was so large even if it contain just couple of regions?
The issue described in this topic looks unique for me. I don't see that any data lost, but I see no reason for such a big file size... Working to figure it out.
on 20/11/2014(UTC)
Offline cecile
#10 Posted : 22 November 2014 21:42:13(UTC)
cecile
France
OK, Maybe it's not worth to spend time on it if I was the only person reporting this trouble.
Anyway, you are now aware it happened once...
thanks to every one who tried.
Cécile
#11 Posted : 26 November 2014 02:07:51(UTC)
Cécile, thank you very much for the report!
#12 Posted : 06 August 2015 05:58:11(UTC)
Corrupted work sheet is not peculiar to Smath. In the process of doing something,
the system does not queue correctly and the work sheet may be partially corrupted,
even worse: TOTALLY corrupted , nothing to do, reconstruct from blank sheet.
In Win XP, a corrupted sheet may appear as an yellow icon 'scrap'. If you open
Word first and slide 'scarp' in Word, it will show what's left as far as Word can
interpret Smath. It did work in Mathcad 11 ,,, as far as work means.
