Hi! I want to save my smath file in to MathCAD file. While i want to open it in MathCAD i get an error Does anybody have an idea how could i solve this problem? If it helps im attachin also .sm file to see GLULAMEdited by moderator 26 April 2016 14:40:56(UTC)
| Reason: marked as issue
Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
Worked for me. File attached.
Thank you man! dont understand what the problem on mine side is
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
I think I can reproduce your issue. I can't test it on mathcad thus I need a feedback. The 1st attachment should works while the 2nd should be corrupted. Edited by user 22 June 2015 18:11:47(UTC)
| Reason: updated files |
Joined: 15/07/2015(UTC) Posts: 13 Was thanked: 1 time(s) in 1 post(s)
Hi, i have the same problem, anyone knows how repair the document?
Originally Posted by: w3b5urf3r_reloaded I think I can reproduce your issue. I can't test it on mathcad thus I need a feedback. The 1st attachment should works while the 2nd should be corrupted. Yes, the first open with mathcad and the seccond fail... How u repair?
Thank you for the feedback! I've already reported it as SS-2272. The settings used by the plugin to save the XMCD file are your system settings (comma as decimal separator, when you get the error). Until a new version of the plugin will be available, you have to change your system settings before launching SMath and then you can save the file. Otherwise the file must be opened with a text editor and you have to fix the xml attributes. |
Thanks for your help, but i change the system settings and the problem is still on. I hope the new version of the plugin be avaible soon to use the Smath with all computers in the job (i'm trying to convince my boss ) See u soon guys, the program is excelent keep in that way!! PD: The file is attached Edited by user 21 August 2015 15:06:31(UTC)
You can try if this works... maybe there is another error... P.S. just to be sure, for "system settings" I mean the OS settings (in Windows 7: Control Panel > Regional and Language Options > Formats > Additional settings) Edited by user 20 July 2015 17:12:41(UTC)
Originally Posted by: w3b5urf3r_reloaded You can try if this works... maybe there is another error... P.S. just to be sure, for "system settings" I mean the OS settings (in Windows 7: Control Panel > Regional and Language Options > Formats > Additional settings) "OS settings" Thanks!!!! The problem was solved, u rocks!
Hi people me again... I have a new problem when i save as .xmcd Attached image and document Like always, thanks! File Attachment(s): Macs attached the following image(s):
4 downloads and no reply... this is serious jejeje
Its an enormous sheet! Have you tried copying it to a new sheet piece by piece and saving to xmcd, until you found what section was causing that error?
1 user thanked Ernesto for this useful post.
Originally Posted by: Ernesto Its an enormous sheet! Have you tried copying it to a new sheet piece by piece and saving to xmcd, until you found what section was causing that error? Hehehe, I have been very busy in this sheet ... To find the error, I did yesterday the same like you (copy to a new piece by piece sheet and save XMCD), and the problem was edited image, when the delete the problem is resolved. Now you know, dont edit images if you want to save XMCD. Have a nice day, and thanks!
Originally Posted by: Macs Now you know, dont edit images if you want to save XMCD. This is not completely true, seems the problem is just on the state of the images. If you uncheck the "edit" button everything goes fine. Bug added in the BTS: SS-2274Edited by user 19 August 2015 18:36:38(UTC)
Fix committed, should be available in the next relase. SS-2274 updated. Edited by user 10 May 2016 12:40:56(UTC)
| Reason: marked as fixed |
