Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Hi I developed an SMath file with a program using a "while" loop. It was working perfectly several times. When I opened it later, there was an empty file with a "Stack Empty" message with an OK button. The file is attached. Can somebody help me please? File Attachment(s): Test.sm (897kb) downloaded 23 time(s). |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1334 time(s) in 877 post(s)
Hello ndtma, There was an error in the code of a WriterRegion... I'll investigate it to find the cause, as for now here is the file fixed (no data lost) Edited by user 11 September 2015 13:20:45(UTC)
| Reason: Not specified File Attachment(s): Davide Carpi attached the following image(s): |
Hello Davide,
Thanks a lot. I spent a lot of time, with expanatory notes using WriterRegion,so that any body could understand it easily. |
1 user thanked ndtma for this useful post.
Nice job I need just an info to catch the bug; do you remember if the text in the image above was a two line text or a single line text? |
Hello Davide,
Your guess is correct. It was a single line originally. Also I noticed that changing some text colors in a notation affected the whole line. Ex. text in the upper part (1. ystart known) have changed to red. |
