2 Pages<12
Offline Andrey Ivashov
#21 Posted : 18 March 2012 18:24:48(UTC)
Rank: Administration
Hello.
TheWizEd wrote:
When I create a new region Parent is Nothing.
Did you try it with SMath Studio 0.93?
Regards.
Offline TheWizEd
#22 Posted : 24 March 2012 18:28:05(UTC)
TheWizEd
United States
Was thanked: 19 time(s) in 13 post(s)
Andrey,
Sorry its taken me so long to get back to you. Been busy with other things.
The Parent was not set immediately after the constructor but I trapped it in OnPaint and its set to a value.
Thanks.
Ed
#23 Posted : 04 June 2012 12:55:01(UTC)
Originally Posted by: TheWizEd Go to Quoted Post
Andrey,
I've finished the controls and posted to the SVN. Have a look and let me know if there are any problems. I'm not a professional programmer so go easy on my coding. As you noted the controls had to reside in a dll with the same name so I couldn't figure how to sub class so I just used switches to manage the controls.
One thing I noted is that the user could cut and paste a control with no way for my program to capture that and rename the control to a unique name, which is needed by the program. Maybe next release.
this work will be implemented in a future relase of smath?
regards,
w3b5urf3r
Edited by user 09 January 2013 20:15:19(UTC)  | Reason: Not specified
on 17/09/2015(UTC)
Offline 9_82abZ2
#24 Posted : 16 September 2015 22:37:21(UTC)
9_82abZ2
TheWizEd,
I am looking at creating the same controls you indicated in this thread.
I am under the impression that you use Visual Basic to generate the controls? Yes? If so, could you walk me through the process you use to generate a button?
I downloaded an analyzed the code for a simple checkbox region and, despite not touching C++ in a while, I was able to modify the given code in C# to some degree (change color, change 'shape' of control). However, I would prefer not to reverse engineer if I don't need to.
Can you (or someone) create a 'control' development tutorial for Visual Studio?
2 Pages<12
