Offline bani.greyling@gmail.com
#1 Posted : 03 November 2015 10:17:53(UTC)
banig
South Africa
Hi
When I do the following, the results are not correct:
Here is the file I used:
Fault.sm (3kb) downloaded 10 time(s).
Bani Greyling
Edited by moderator 20 May 2016 20:58:52(UTC)  | Reason: marked as solved (not a bug)
Online PompelmoTell
#2 Posted : 03 November 2015 11:36:13(UTC)
PompelmoTell
You must use the unit of measurement for temperature differences
Offline banig
#3 Posted : 03 November 2015 11:46:23(UTC)
banig
South Africa
Thanks
I understand now what is happening: 300K + 10C -> 300K + 283.15K = 583.15K
Bani
#4 Posted : 04 November 2015 04:47:28(UTC)
Originally Posted by: banig Go to Quoted Post
300K 10C -
_______________________________________
Your understanding is correct: the unit of temperature is °K.
Working with unit means consistant system, particularly true
working trig functions.
That freeware "Uconeer 2.4" from Katmar is most precious.
Some smart decided the triple point of water that was 0 °C
is now 0.01°C
on 05/11/2015(UTC)
