Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Hello Alex That's an interesting idea; I've something in my mind but is not yet fully defined. Now I'm working to complete a new plugin, then I'll start to update the core of the table region, I know there are several bugs to fix and things to add. This will require time. Of course you can play with the code, there aren't restrictions Edited by user 02 December 2015 02:34:03(UTC)
Hi Davide,
I looked at the code - it seems to be somewhat out of my league (at least for now). I might just wait till you decide it is time to use table region for matrix creation.
Thank you for your hard work here!
1 user thanked Alex M. for this useful post.
Originally Posted by: mkraska a convincing example of where display contents editing is useful. _____________________________ I agree with Martin: 1. If your matrix is wrong: recreate the same way you did "wrong" but this time "right" 2. If you create a matrix from a *.PDF, address the element you want to correct. 3. You can extract "row', "col" 4. You can insert row(s) by submatrix and stacking. 5. You can insert col(s) by transposing by [4. above] and re-transpose. If you are given a horse, don't ask for the saddle. à cheval donné: ne demande pas la bride "Edit" is a very large word, especially if not exemplified. No work sheet = No problem ! Jean
This work sheet may be useful. Many important modules are missing: 1. Replace part of a matrix by another one. 2. Insert row(s)/col(s) at specific position. ...etc. Jean Utilities Matrix.sm (162kb) downloaded 145 time(s).
As shown in the attached image, I encounter a problem using SMath-formatted labels for table headers. This problem did not exist in previous versions as highlighted in the image. In particular, the problem seems to be limited to the use of "." for the subscript. I note that the opening "TableRegion.sm" of the sample file causes the program to crash Smath (only in version 098.6356). sergio
1 user thanked PompelmoTell for this useful post.
Thank you Sergio, please try with the updated plugin |
Joined: 28/08/2013(UTC) Posts: 18 Was thanked: 2 time(s) in 2 post(s)
Wow I had no idea this plugin even existed. Thanks so much to the SMath contributors and especially Davide for this plugin.
Ok works as well as before thank you Davide
Davide, I looked through the example files but I didn't see anything that addressed my situation. I'm not sure if this is even possible or if I overlooked the option. Is there a way to word wrap the header to fit a set width for the numeric table values? The second table in the screenshot is similar to what I'm trying to achieve. I also made a quick example in excel to help illustrate. I was also going to use the footnote option as an alternative but I'm came across a similar problem where I couldn't widen the note section since it appears dependent on the table width.
Hello
uncblue
, I guess this feature is not available (I have to double check the code but I'm almost sure I haven't ooded it). This plugin has a lot of room for improvements (and several fixes), I'll try to come back on it in the future! |
Originally Posted by: Davide Carpi Hello
uncblue
, I guess this feature is not available (I have to double check the code but I'm almost sure I haven't ooded it). This plugin has a lot of room for improvements (and several fixes), I'll try to come back on it in the future! Ok, that sounds great. I'm so glad I came across this plugin because I was creating "ugly" tables manually before I found this.
Was thanked: 21 time(s) in 17 post(s)
Hi, found an issue in Version 0.1.6395.15149, using SMath 0.98.64.84. It is related to using commas (,) for decimal separator. The plugin seems to replace every point with a comma, also where used as subsript. e. g. "BS,k" (the string "BS,k" cannot be found in the sm-File). Tables work well if point as decimal separator is used. Bevor calculation: After calculation:
Nested arrays as input for a table don't work anymore, too.
Thank you
MarB
, I'll look into it ASAP |
on 04/10/2017(UTC), on 06/10/2017(UTC)
PLUGIN UPDATED SMath Studio 0.98.6484 and later- provided access to settings via context menu;
- fixed some issues related to Session' Profile compatibility;
- SS-120: fixed issues with nested matrices;
- SS-2394: fixed decimal places/significant figures settings not stored;
- significant figures algorithm refactored;
5 users thanked Davide Carpi for this useful post.
on 08/10/2017(UTC), on 09/10/2017(UTC), on 09/10/2017(UTC), on 09/10/2017(UTC), on 09/10/2017(UTC)
Thanks for your improvement, Davide. In following screenshot you can see the following behaviour: With number format set to default... - numbers are always written with exponent (left/right stub also) - strings are printed with surrounding "" and Expressions are not formatted By changing the number format to number, everything looks as usual. Is that intended?
1 user thanked MarB for this useful post.
Thank you, it's a bug indeed, I'll fix it later today. |
please try again now
PLUGIN UPDATED |
Looks good. Units are printed black, upright (not blue, italic). But why not?
Originally Posted by: MarB Looks good. Units are printed black, upright (not blue, italic). But why not? Fixed, it was not intentional, thank you again Edited by user 11 October 2017 03:29:24(UTC)
