SMath Studio Forum
Bugs & Problems
Need urgent help - result is above max. positive number
Hey guys, I was working on a very long custom function that I will need to use in short 9 hours (in the morning after I will wake up) and got this error at the end "result is above max. positive number". Error shows itself if for function input I use larger matrix (see workbook for details). Could you help please? Thank you! Error.sm (76kb) downloaded 26 time(s).Edited by moderator 21 May 2016 02:24:46(UTC)
| Reason: marked as solved
Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
Got it working. I added eval() over pretty much all the operations of that huge function. I don't think they all required it, but it would've taken time to sort that out. Might want to double check I didn't accidentally change a line. Good luck. Error.sm (78kb) downloaded 33 time(s).
1 user thanked Ernesto for this useful post.
Originally Posted by: Ernesto Got it working. I added eval() over pretty much all the operations of that huge function. I don't think they all required it, but it would've taken time to sort that out. Might want to double check I didn't accidentally change a line. Good luck. Error.sm (78kb) downloaded 33 time(s). Thank you very much, Ernesto. I had no clue eval() would make such a huge difference. I'm all set for tomorrow (or should I say for today).
Originally Posted by: Alex.M Thank you very much, Ernesto. I had no clue eval() would make such a huge difference. I'm all set for tomorrow (or should I say for today). _________________________ I visited both work sheets. The first one didn't show any error message. The Sigma is always suspicious. In one of my applications it is limited to N = 11. In another application [Ksmooth] it did correct up to N = 24. Same "Ksmooth", I tried on longer data set and failed. "Ksmooth" consumes enormous amout of computing power, even Mathcad 11 pedals ! My understanding of "Result is above of max allowed positive number" the execution stack is full, like in the older HP calculator. My next understanding is that eval(,) computes intermediate results, thus reducing the length of the stack. That's what my "finger meter" tells me. Cheers, Jean
SMath Studio Forum
Bugs & Problems
