Hello, i have a lot of problems with units if i want mm the program makes m if i want N/mm2 the program makes Pa is it possible to defin it ? how do you do it ?
Hello Jonny, Units in results are by default in base units. You can set the more appropriate units for the single result writing in the rightmost placeholder ( wiki: units) If you are interested to have default output units you can register in the Bug Tracker System and vote SS-1Edited by user 21 May 2016 02:22:00(UTC)
| Reason: marked as solved |
So nice your demo , Davide ! Thanks for that vivid Smath tutorial.
Hello Jonny:
"Uconeer" is a freeware unit converter from "Katmar Software" Very useful for Engineering works. From same "Katmar Software" you can download "Wasp" [Water Steam Properties].
