2 Pages12>
Offline Andrey Ivashov
#1 Posted : 02 March 2016 01:07:51(UTC)
Rank: Administration
SMath Studio 0.98.5905 available
Latest changes (against SMath Studio 0.97.5890)
  • Calculation performance significantly improved (see timings in the following screenshots);
  • SS-2297: Numeric comparing of matrices with different dimensions fixed (issue happened when values in both matrices were the same but dimensions differ);
  • Keystroke fixed for adding Separator region;
  • Logic of handling plug-ins to evaluate expressions completely redesigned (it became much more efficient);
  • Critical issues fixed happens for some types of evaluation plug-ins;
  • Fixed issue appears when two or more plug-ins handles the same Term;
  • List of loaded plug-ins sorted alphabetically into Extensions Manager;
  • MSI installer became 20% lighter then for previous version;
  • Automatic release date setting on build implemented (no incorrect dates in About dialog anymore);
  • Refactoring.
Download
P.S.: Congratulations on coming of the springtime!
Edited by user 02 March 2016 16:30:08(UTC)  | Reason: Not specified
thanks 5 users thanked Andrey Ivashov for this useful post.
on 02/03/2016(UTC),  on 02/03/2016(UTC),  on 02/03/2016(UTC),  on 02/03/2016(UTC),  on 03/03/2016(UTC)
#2 Posted : 02 March 2016 01:26:31(UTC)
Hello all.
I'm very excited about this release as it is actually the most significant code change for past several years. I've started working on core redesigning (in order to improve performance) on summer 2015 and today results are published! I did my best to provide full back compatibility for plug-ins, but I expect couple of them might be failed to load. If so, please let me know, so I could fix it.
This SMath Studio build passed all internal tests and I believe it is stable enough to start using it today, but just because of too many changes done it will be more safe to check all possible behaviors together before finally releasing it as Stable officially.
Best regards and happy playing with SMath Studio 0.98!
on 02/03/2016(UTC),  on 02/03/2016(UTC),  on 02/03/2016(UTC),  on 02/03/2016(UTC),  on 02/03/2016(UTC)
Offline Alex M.
#3 Posted : 02 March 2016 01:57:54(UTC)
Alex M.
Originally Posted by: Andrey Ivashov Go to Quoted Post
Hello all.
Thank you Andrey, this update is most welcome!
To start off the bug hunt - something does not seem to work for summation:
... And for one reason or another a "attach file" icon is not visible in the forum post menu...
Here is the SMath expression code that does not work:
line 1 :
Code:
y':transpose(mat(-3*'m,3*'m,3*'m,-3*'m,1,4))
line 2 :
Code:
I.x:sum(((el(y',i))^2),i,1,N)
In the cloud: http://smath.info/cloud/sheet/MZvkmGNbq6
Error in the cloud version of SMath is different from the error in the local version
Edited by user 02 March 2016 02:07:22(UTC)  | Reason: Not specified
thanks 1 user thanked Alex M. for this useful post.
on 02/03/2016(UTC)
Offline ndtma
#4 Posted : 02 March 2016 06:23:13(UTC)
ndtma
Sri Lanka
Hi Andrey!
Thanks very much for the new version.
I observe the following.
1. FindRoot function does not work.
2. Definite integral does not work.
on 02/03/2016(UTC)
#5 Posted : 02 March 2016 09:14:33(UTC)
Thank you all! Current nightly build is canceled and will not come as an update anymore. Will do release later this week after all issues is fixed.
For now I suggest you to uninstall 0.98 and install the latest available 0.97.
Sorry for inconvenience!
UPDATE: As we see issues is not actually related to SMath Studio itself, 0.98.5904 is now approved as a Beta again. It will be available via Extensions Manager if it is configured to display Beta-versions of files.
Edited by user 02 March 2016 12:43:03(UTC)  | Reason: Not specified
on 02/03/2016(UTC)
#6 Posted : 02 March 2016 09:46:04(UTC)
I do not see any errors. You need to specify N to calculate it (the same for last 0.97)
on 02/03/2016(UTC)
#7 Posted : 02 March 2016 09:47:40(UTC)
Today ther is no file attachment in the post reply.
Attachment fixed for Nightly Build forum (feature was just disabled for this forum).
#8 Posted : 02 March 2016 09:53:06(UTC)
Everything works as expected for me:
Please help to reproduce.
on 02/03/2016(UTC)
#9 Posted : 02 March 2016 09:57:09(UTC)
Hello, Ioan.
Originally Posted by: ioan92 Go to Quoted Post
Never mind on the unavoidable problems linked to the progress.
Thank you! Good Yes, together we are able to handle all possible complexities!
#10 Posted : 02 March 2016 11:48:07(UTC)
Not yet experienced problems, and indeed is faster than the 0.97, thank you very much OK
except some functions as Min and Max, belonging to a Davide's plugin.
Can you share an example, seems to me that they works Good
Edited by user 02 March 2016 11:49:53(UTC)  | Reason: Not specified
Offline ndtma
#11 Posted : 02 March 2016 14:05:51(UTC)
ndtma
Sri Lanka
The following file worked well in Smath 97.5890 up to yesterday.
But under the latest version, the calculation for definite integral gives an error.
Can somebody help me in this regard please?
Reservoir Flood Capacity Estimation-R1.sm (191kb) downloaded 57 time(s).
Offline omorr
#12 Posted : 02 March 2016 15:11:41(UTC)
omorr
Serbia
Hi Andrey!
It will not work for me as well, although I have to admit that I installed bunch of plugins.
However, fresh install with only Davide's Nonlinear Solvers (FindRoot() function is from there) and Martin's Smath Handbook will give this
1. FindRoot() will give the same error as on the picture
2. Definite integral works
Edited by user 02 March 2016 15:13:22(UTC)  | Reason: Not specified
on 02/03/2016(UTC)
#13 Posted : 02 March 2016 15:35:30(UTC)
NonlinearSolvers updated, try now Good
I have no problems with integrals, no exceptions in the files above (Reservoir Flood Capacity Estimation-R1 / TestSum).
Edited by user 02 March 2016 15:43:56(UTC)  | Reason: Not specified
on 02/03/2016(UTC)
#14 Posted : 02 March 2016 15:53:58(UTC)
Cannot reproduce Sad
on 02/03/2016(UTC)
Offline ElSid
#15 Posted : 02 March 2016 16:14:13(UTC)
ElSid
United States
Thank you Andrey and to all the developers!
Still hoping for an official portable version ...
Any information on the symbolics? I am trying to recreate a "proof" from a Mathcad file and I'm missing some features (or cannot find). Are we allowed to post Mathcad files on this forum? If so, I will post all of the relevant files.
Offline omorr
#16 Posted : 02 March 2016 16:59:16(UTC)
omorr
Serbia
@Radovan,
@Davide,
Please, can you reproduce the error with the file in post #18?
Small delta region can be desabled.
Best Regards,
Ioan
I can reproduce this on the machine with many plugins, but on the machine with almost no additional plugins it was correct.
Therefore, chasing for the problematic plugin should be performed regarding these problems (integration, summation etc).
@Davide
Did you update the Numerical Solvers? I did not find any difference yet regarding FindRoot() problem
Offline Alex M.
#17 Posted : 02 March 2016 17:00:02(UTC)
Alex M.
Hi Andrey, apologize for confusion. I have a 30 page SMath file that does not run on 0.98; The error points down to the summation function - I will attempt to replicate it again and post the .sm file here
Offline omorr
#18 Posted : 02 March 2016 17:16:28(UTC)
omorr
Serbia
Hi Andrey!
Try to install a fresh version without any not needed plugin for this file.
I suppose it might work, not sure.
Offline ndtma
#19 Posted : 02 March 2016 17:29:36(UTC)
ndtma
Sri Lanka
Hi Radovan,
I had a bunch of so many plugins.
So, uninstalled, including all plugins in %APPDATA%/Smath folder and did a clean install.
My problem was solved.
Thank you very much.
Edited by user 02 March 2016 17:32:19(UTC)  | Reason: Not specified
Offline ElSid
#20 Posted : 02 March 2016 17:48:57(UTC)
ElSid
United States
Originally Posted by: ElSid Go to Quoted Post
...Any information on the symbolics? I am trying to recreate a "proof" from a Mathcad file and I'm missing some features (or cannot find). Are we allowed to post Mathcad files on this forum? If so, I will post all of the relevant files.
Specifically, I thought that "symbolic solve of algebraic equations" was implemented in version .9X. Keywords in symbolics would be fantastic too!
From Mathcad
Guest (2)
2 Pages12>
