Offline ndtma
#1 Posted : 05 March 2016 05:48:32(UTC)
ndtma
Sri Lanka
The following Smath File worked fine under 97.5890. It opens a Excel data file for analysis.
But it crashes under 98.5905.
Why this happens?
Test-Op_Study.sm (78kb) downloaded 23 time(s). DailyQ_Malwala.xlsx (86kb) downloaded 22 time(s).
#2 Posted : 05 March 2016 14:08:32(UTC)
The crash is triggered in sum(1)
Even copying the Q matrix in a definition on the canvas the crash still happens. Crazy
Issue isolated: crash sum 1.sm (319kb) downloaded 21 time(s).
P.S. try sum(identity(30)) and sum(identity(50)), the second one crashes for me
opened as issue SS-2302
Edited by user 21 May 2016 02:21:02(UTC)  | Reason: marked as fixed
#3 Posted : 05 March 2016 14:59:45(UTC)
Try this instead
#4 Posted : 05 March 2016 15:07:29(UTC)
... sorry, forgot to attach the file
crash sum 1.sm (323kb) downloaded 19 time(s).
Offline ndtma
#5 Posted : 05 March 2016 18:44:48(UTC)
ndtma
Sri Lanka
The second one crashes for me too
on 05/03/2016(UTC)
Offline Andrey Ivashov
#6 Posted : 06 March 2016 00:33:25(UTC)
Rank: Administration
on 06/03/2016(UTC),  on 06/03/2016(UTC)
#7 Posted : 06 March 2016 02:55:35(UTC)
Ioan,
You can dedicate a function "VectorMatrixSum(data)"
Unwrap has many more applications, thus interesting.
Under the hood, your combined Sigmas, they first
Unwrap. Matrices don't exist in computing Machinery.
Matrices exist as serialised components.
The "BombCompute Mathcad 11", copy/paste a fair size
matrix [16000000 per say] takes substantial time.
"Warning: the requested operation may take long time".
Can't be more true.
Cppy/paste 16000000 vector: NO warning message... done.
Chers, Jean
Offline ndtma
#8 Posted : 06 March 2016 15:49:45(UTC)
ndtma
Sri Lanka
Thank you Andrey.
The problem on Smath file crash is now solved.
on 06/03/2016(UTC)
#9 Posted : 07 March 2016 06:44:24(UTC)
Originally Posted by: ndtma Go to Quoted Post
Thank you Andrey.
"now solved", maybe not so wrt matrix manipulation.
Observe the matrix scale code: M-Min(M)
I found out this built-in code is weak, prone to failure
with incorrect error message " Matrix is not invertible".
There is no matrix inversion involved. Observe the robust
code doing same. Example has low numerical values. At values
in the order of 10^10, module [1] fails.
Utilities Matrix Scale.sm (15kb) downloaded 22 time(s).
on 07/03/2016(UTC)
