SMath Studio Forum
Feature Requests
"include" plugin: default directory setting
When using include plugin, it's sometimes inconvenient to use full paths, esp. when working on different setups. E.g., at work, I would like to have a network share with library files, which are included in a number of working files. At home, I would like to copy the whole library someplace at my PC, and continue to work with my workfiles. Currently, I only can do it introducing some string path variable and setting it at each place. The proposal is to add a setting for include plugin, so that it's possible to setup a "library" (default location) path, and in case of relative paths in include(), look there. Btw, is there in SMath an interface to add to settings dialog, or to Tools menu? Edited by user 04 April 2016 13:32:56(UTC)
Best regards, Mike Kaganski |
You can use relative paths but for the "\extensions\" directory only for now. You can download Linq.sm example from the gallery and use it with the command:
include("examples\Linq.sm" )=
I can change this behavior. |
Oh, yes, you see, it's not convenient with \extensions\ as it is now. It wouldn't be great for any fixed directory, either, that's why I ask for customizable (at program level) directory, if possible.
Thank you! |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,649 Location: Italy Was thanked: 1333 time(s) in 877 post(s)
Originally Posted by: mikekaganski Btw, is there in SMath an interface to add to settings dialog, or to Tools menu? Nope, but it is possible to support the request of such feature here: (SS-70) |
SMath Studio Forum
Feature Requests
