Jean,
The two versions (install and portable) come out exactly with the same plugins; in a system that has never seen SMath Studio before, you don't notice differences.
If you have used SS with installer before, you may experience differences because all the 3rd party plugins, those downloadable from the Extensions Manager, are kept in the AppData folder of the user (they are not deleted when you uninstall/update the program).
Portable version doesn't use the AppData folder, all the settings and plugins are kept inside the folder of the executable (because is portable, so you have always the same settings and plugins in any system you run the program, despite what is installed or not installed in that system); hence even if you have the two versions running in the same system, they may be different depending on the history of each one.
There are 2 ways to obtain and keep updated the 3rd party plugins:
- manual install/update: tools > plugins > online gallery; here you see all the plugins not yet downloaded as well as the updates of those you have already downloaded (the latest are highlighted in blue). As for now there isn't an automatic "check for updates" (like the one that notify when there is a new SS available).
- auto install/update: when you use a function or a region in a worksheet, SMath Studio should save the dependancy in the file; when you or another person open the file, a check is done by the Extensions Manger and notice you if a missing or newer plugin is needed to run the worksheet as designed. By following the prompted forms, you can download them or not, and run the worksheet (even without these plugins).
Aside (still important) notes:
- since a while (SS 0.96.4902) developers are able to provide updates for older SMath Studio version, through the Extensions Manger, in which is possible to compile the plugins for a specific SS version to the latest; this means that as principle is possible to share new features of exiting plugins even for older version. This is easier for some range of versions, since the APIs are similar and there are none or few changes to do to compile these plugins. When there are big changes introduced by the APIs, this may becomes harder, thus compatibility may be broken (still possible, if all the required features were available in some way even in the older versions, and the developer has enough time to modify the code
for any version up to the oldest required).
- some changes in the APIs are required, other not strictly required but auspicable; 0.98 has introduced several changes for stability (even a long awaited fix in the save routine, that has made a lot of victims). I expect other in future, and probably the may affects back-compatibility (f.e. see
SS-2318 or
SS-1258); fortunately, all the SS version are available, so one may use a portable version to load newer or older worksheets (as his needs) and try to convert;
- targeted patches for the core seems a good idea, even if it really depends on the developer (time to provide these patches, compatibility/update philosophies; this is tipically the approach of many commercial products, where you pay to use a version, and you can't use newer versions without buying a new license; it is also adopted in some free software, where there are many developers (here we have only one). In both these products, the support/patches at a certain point ends or become really expensive)
Edited by user 09 May 2016 13:10:06(UTC)
