2 Pages12>
Offline Basile
#1 Posted : 25 June 2016 01:13:55(UTC)
Basile
I am getting the following:
Basile
Offline Razonar
#2 Posted : 25 June 2016 03:39:49(UTC)
Razonar
Uruguay
Hi Basile.
That's is the expected way to work with smath.
To get the value of X.C you must to call the function after defining X.C with X.C(f)=
Offline Basile
#3 Posted : 25 June 2016 04:34:38(UTC)
Basile
Alvaro,
Look to the left the of X.C , the X.L
Should behave the same?
Basile
Offline Razonar
#4 Posted : 25 June 2016 05:02:38(UTC)
Razonar
Uruguay
Originally Posted by: Basile Go to Quoted Post
Alvaro,
Basile
Depending which version, it could be. I guess that must to be an election from author, this is, if eval functions in that way. The "not evaluation" option, as the attached picture, it's ok for me.
Offline Basile
#5 Posted : 25 June 2016 05:13:38(UTC)
Basile
i am using
Basile
#6 Posted : 25 June 2016 06:46:19(UTC)
Same problem as before: you have no circuit, then no LC project.
The only thing you can do is calculate the resonance frequency: 'fo'
Then plot it as sin(fo)
Offline Basile
#7 Posted : 25 June 2016 15:41:27(UTC)
Basile
Jean,
I am calculating the reactance of the inductor and the capacitor at a frequency f.
Basile
#8 Posted : 25 June 2016 19:53:44(UTC)
In my times, pure L, C were strictly imaginary. Just by themselves they don't have much use
whereas there is no such thing as pure L , pure C. They both have physical resistiviy.
Offline Basile
#9 Posted : 26 June 2016 00:30:56(UTC)
Basile
Jean,
You are right that:
X.L=jωL
and
X.C=-j(1/ωC)
and the magnitude is that I calculate.
You can simply consider ideal elements without the loss resistance.
Basile
Offline Razonar
#10 Posted : 26 June 2016 03:51:28(UTC)
Razonar
Uruguay
Hi Basile. That's isn't.
Correct XL and XC (reactances) are without j, as in your worksheets.
ZL and ZC (impedances) are with j.
Actually the total impedance is Z = R + jX, where X = XL + XC is the total reactance.
Offline Basile
#11 Posted : 26 June 2016 06:35:47(UTC)
Basile
Alvaro,
You are confusing things.
What you say are correct but have to do nothing to do with the question.
X.L, X.C are reactance (with j or without j)
Z is impedance of R and X.
Basile
Offline Razonar
#12 Posted : 26 June 2016 07:03:00(UTC)
Razonar
Uruguay
Alvaro,
Basile
Hi Basile. I don't confusing. Reactances ( https://en.wikipedia.org/wiki/Electrical_reactance ) are reals and impedances ( https://en.wikipedia.org/wiki/Electrical_impedance ) are complexes. So X.L, X.C can't have j.
About the numerical evaluation for a function, check this old post: http://en.smath.info/for...nction-as-a-program.aspx
In X.L, X.C definitions as functions, f must to be a local variable. X.L(f) -> (symb evaluation) must to set the answer with "f", not with "100 Hz". And the numerical evaluation X.L(f) = must to be in red, as f as local variable isn't defined.
As a choice of the program writer, and what you can see in the last post of the above referenced, you can set all the local variables as globals with f(x) = 1*(line ... ). Actually I'm not comfortable with that behavoir, but is the choice of Andrei.
#13 Posted : 26 June 2016 08:01:29(UTC)
Just like this Basile, for a family of "C's"
at a fixed frequency 8 the magenta line.
On the plot, 'f' => 'x'.
Offline Basile
#14 Posted : 26 June 2016 20:59:10(UTC)
Basile
Jean,
Yes, I can plot X.C(f) and X.L(f) but if I try to plot the difference or take the aritmetic difference does not work.
Please see figure and figure in post #1 on top, if it helps.
Basile
#15 Posted : 27 June 2016 01:42:21(UTC)
Basile, let's make it clear on three points:
1. You have no work sheet, then there is no project [no help].
2. Read this link again https://en.wikipedia.org/wiki/LC_circuit
to help you start onstruct a project.
3. Those gyzmas: they do nothing circuit wise.
Offline Basile
#16 Posted : 27 June 2016 06:00:18(UTC)
Basile
Jean,
Attached please find the file.
test resonance.sm (8kb) downloaded 22 time(s).
Basile
#17 Posted : 27 June 2016 16:15:28(UTC)
... project done Basile.
Circuit [LC].sm (19kb) downloaded 20 time(s).
#18 Posted : 27 June 2016 16:17:47(UTC)
Note that I have removed the unit system because
"Units don't match" error mesage ... so: zap !
Offline Basile
#19 Posted : 27 June 2016 17:03:08(UTC)
Basile
Jean,
"why units do not match? Are they both Ω?"
Basile
PS: Thank you for the discussion.
Offline CBG
#20 Posted : 27 June 2016 19:54:29(UTC)
CBG
Redefining subtraction or function.
test resonance_CBG.sm (11kb) downloaded 14 time(s).
Guest (2)
2 Pages12>
