Offline Basile
#1 Posted : 25 June 2016 01:45:22(UTC)
Basile
X-Y plot plotting two functions:
Basile
Edited by moderator 26 June 2016 13:49:46(UTC)  | Reason: title updated - marked as bug
Offline Razonar
#2 Posted : 25 June 2016 03:35:35(UTC)
Razonar
Uruguay
Hi Basile. A bug without the file could be hard to interpret.
But, unregarding math or bugs, you're trying to use negative frequencies. Are you sure about what could be represent that? Also, a zero frequency, what is it? Direct current?
Frequencies also are usually represented in a log scale.
Offline Basile
#3 Posted : 25 June 2016 04:42:36(UTC)
Basile
Alvaro,
All you say about the physics of the problem, you are right.
But look the mathematics, just plotting a function.
Look above, the X.L(f) plots fine.
Similarly plots fine if I use the Plot-2D.
Basile
Offline Razonar
#4 Posted : 25 June 2016 05:19:22(UTC)
Razonar
Uruguay
Hi Basile. You discover a couple of nice and unwanted visual special effects in blue. I know near nothing about smath plugins, and can't help about them.
#5 Posted : 25 June 2016 06:38:12(UTC)
Two things Basile:
1. Your unit systen is wrong [L => H, C => F]
2. Xc, XL have nothing to do with an LC circuit.
XL is equal to f(x):= dontknow*x
XC is equal to f(x):= 1/dontknow*x
https://en.wikipedia.org/wiki/LC_circuit
Offline Basile
#6 Posted : 25 June 2016 15:38:01(UTC)
Basile
Jean,
My system of units is NOT wrong.
Capacitance in Farad
Inductance in Henry
Reactance of both in Ohm.
Basile
#7 Posted : 26 June 2016 13:51:00(UTC)
Seems the issue is related to negative infinity
#8 Posted : 26 June 2016 15:18:34(UTC)
Basile,
What you did is no not correct: You copied the L
plot and put in it the C plot with the same L scales.
So, the C plot flies in the blue. Someting like this:
If you photograph a mouse and an elephant in the same
bed, you won't see both. If you adjust for elephant,
the mouse will be a dot pretty hard to isolate and
enlarge unless you have zillions of MP resolution ...
#9 Posted : 26 June 2016 15:27:34(UTC)
Forum Basile Plot.sm (5kb) downloaded 15 time(s).
Offline Basile
#10 Posted : 26 June 2016 20:31:03(UTC)
Basile
Jean,
Yes, it works with the Plot 2D.
The problem is with the X-Y plot. It disappears and freezes the instance of Smath!
As pointed by Davide a possible problem with minus infinity?
Basile
#11 Posted : 26 June 2016 22:05:08(UTC)
NO => Not as you think. X_Y is not an autoplot, it is a plot range.
If you plot sin(x) it falls in its default XY ranges OK. Otherwise
you have to range both directions. X_Y does not supports few things:
1. It does not plot x. It does not understand that 'x' is implicit
of 'x' = "1*x" neither implicit of 'x' = 'x+0'
2. It supports some common Engineering ranges 1*e ±3 [per say]
but will crash Smath instance if you want to range 1*e ± -15
X_Y is lovely in many projects but not in others.
Offline Ber7
#12 Posted : 29 June 2016 19:02:35(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
By increasing the limit values of the function  the graph does not
pass through a pivotal point
Bug.sm (9kb) downloaded 13 time(s).
#13 Posted : 29 June 2016 20:31:53(UTC)
That's right but not a bug. Just that above the Y magnitude 45,
the canvas misses some points in the critial region.
More: does not fill the circle, plots x instead of +
X_Y Plot wisely.sm (12kb) downloaded 18 time(s).
on 29/06/2016(UTC)
#14 Posted : 29 June 2016 20:38:02(UTC)
Guest (2)
