SMath Studio Forum
Bugs & Problems
Problem Dividing Second Term With Units
sMath Studio: 0.98 (5935) I am trying to enter the equation at the top of page 17 of this intro guide: http://smath.info/wiki/G...MathStudio088May2010.pdfThe first multiplicand with units goes in fine, as does the numerator with units of the second multiplicand. However, SMath Studio will not permit me to enter a denominator under the full numerator (value and units) of the second multiplicand. When I press the space bar, various objects become underlined, but never the entire numerator (with units) of the second multiplicand: I then am unable to enter the denominator under the complete numerator (value with units) of the second multiplicand. Is this a bug, or user error? How to fix? Note: I can enter the values, and then return and enter the units, but I would prefer to do it in one pass. Thanks. Edited by user 05 July 2016 03:44:17(UTC)
Does not work for me either. 2010 is pretty old ....
Now it works but it has do do with the exponential threshold, but not mentionned at all
μN => exp threshold [6] mN => exp threshold [3] N => exp threshold [9]
No problem to enter the denominator. Open brackets first, type the stuff, square
Cheers collab.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,656 Location: Italy Was thanked: 1341 time(s) in 880 post(s)
Originally Posted by: ISawThatToo Is this a bug, or user error? How to fix? I think that should be considered a bug or at least a missing feature in the user interface. When you write a new formula: add a division before writing the second multiplicand Code:2.5 ► 'mg ► [space or right arrow] ► * ► / ► [numerator] ► [right arrow] ► [denominator]
To edit an existing formula probably the fastest way is to transit through the plain text (copy the whole formula in a text region or in notepad, wrap the multiplicand in curly brackets, copy and paste back as math -> the multiplicand will be selectable) Edited by user 05 July 2016 13:30:14(UTC)
Yes David,
for this case with units, I should have written: 1. edit the firt term 2. call *, call divide 3. edit numerator 4. edit denominator: Open brackets first, type the stuff, square 5. edit result from the unit menu 6. finish editing the result
SMath Studio Forum
Bugs & Problems
