SMath Studio Forum
Bugs & Problems
[SV-2373][PRO] can't open Smath Viewer files
If you protect a region with a password, and this region is closed , to save the "sm " executable ( " .exe" ) Smath Viewer Pro file is not recognized as a Windows executable . and if you save it as " exe " file Smath Viewer free , the file is saved correctly and is recognized by windows , but there is no way that within the executable , you can open the protected region. Best Regards Carlos Edited by moderator 10 September 2016 20:34:59(UTC)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1334 time(s) in 877 post(s)
I cannot reproduce the issue. Could you attach a simple example? Edited by user 01 September 2016 11:45:36(UTC)
With a simple example, Smath Viewer, stopped working . Annex example Best Regards Carlos Test_Region_Protect.7z (927kb) downloaded 50 time(s).
Thank you! I see the problem is related in some way with the separator as first region (title modified). There is a conflict between the separator title and the collapsed encrypted area. Bug added in the BTS ( SV-2373), I'll investigate code-side ASAP. Edited by user 01 September 2016 12:29:54(UTC)
Hello Davide:
The 0.98 build 6089 Smath Studio new version solves the problem for Smath Viewer Free , but not for the PRO version.
One question: Is it possible that you can open a protected region inside of Smath Viewer ?
Thank you.
Hello Carlos, Originally Posted by: CBG The 0.98 build 6089 Smath Studio new version solves the problem for Smath Viewer Free , but not for the PRO version. confirmed, thank you Originally Posted by: CBG One question: Is it possible that you can open a protected region inside of Smath Viewer ? If the encrypted region is not collapsed, everything should works as expected; if it is collapsed, you can't see values generated from inside this area (currently listed as bug SV-2374) Edited by user 31 October 2016 17:29:54(UTC)
| Reason: marked ad solved |
SMath Studio Forum
Bugs & Problems
