23 Pages«<1213141516>»
Offline alyles
#261 Posted : 08 September 2016 20:30:37(UTC)
alyles
United States
Originally Posted by: uni Go to Quoted Post
Originally Posted by: arielyles Go to Quoted Post
Not sure if this is a maple wrapper issue but thought I would start here. I'm using the new version of SMATH (6081) and Version 1.0.6067.40150 of Maple Wrapper.
When I use simplify, it converts a variable with 'I' to 'i'. See attached .sm file. Notice "I.BIAS" in the input and the "i.BIAS" at the output.
example.sm (5kb) downloaded 70 time(s).
Fixed and updated. Try now.
Confirmed fixed. Thank you!
Offline Razonar
#262 Posted : 09 September 2016 03:50:35(UTC)
Razonar
Uruguay
Hi. I found this procedure interesting.
maple_2nd.sm (11kb) downloaded 58 time(s).
#263 Posted : 09 September 2016 05:52:56(UTC)
Alvaro,
A Mathcad Frobenius document was done in our times.
A "visible" document. I will look at it for Smath.
From recollection, it does not need Maple.
Offline Razonar
#264 Posted : 09 September 2016 06:40:40(UTC)
Razonar
Uruguay
Alvaro,
Jean! "Our times". What's that?!.
#265 Posted : 09 September 2016 15:11:45(UTC)
... at the time "you and me" were Mathsoft Collab.
I confused myself with "Frobenius". I thought
of the non-linear DE coefficients. In this Maple
Frobenius is about some matrix "norm".
Some literature refer Frobenius norm to Euclidean
Euclidean norm is "norme", built-in Smath.
Cheers , Jean
Offline uni
#266 Posted : 10 September 2016 12:07:19(UTC)
uni
I confirm that the plugin works on Ubuntu 16.04. You need to manually set the rights for cmaple.exe (chmod 755 cmaple.exe).
Snimok ehkrana ot 2016-09-10 14-04-08.png (896kb) downloaded 37 time(s)..
Edited by user 10 September 2016 12:13:54(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 10/09/2016(UTC),  on 10/09/2016(UTC)
Offline uni
#267 Posted : 11 September 2016 09:09:05(UTC)
uni
Updated. Setting permissions automated (for Linux).
Russia ☭ forever
Offline alyles
#268 Posted : 19 September 2016 18:12:11(UTC)
alyles
United States
I encountered another issue. This seemed to occur with recent update. I'm not sure if this is plugin related or PC related. However, I get this error when I try to use Maple Wrapper. Using most recent version of MapleWrapper and Smath Studio.
Any help would be greatly appreciated.
Offline alyles
#269 Posted : 19 September 2016 18:42:56(UTC)
alyles
United States
I did something to make the cmaple.exe become a runaway process. It was taking up ~ 1GB of memory. Not entirely sure how I did that but force closing cmaple.exe fixed this particular issue. I'll try to figure out what caused the runaway process in my sheet.
Seems like user error after all.
Offline uni
#270 Posted : 19 September 2016 19:10:35(UTC)
uni
It's a good idea to check process status. I'll try to implement this in maple() function.
Russia ☭ forever
Offline uni
#271 Posted : 19 September 2016 19:40:23(UTC)
uni
Also, I found an issue in maple() function. In some cases the symbolic expression could not have multiplication sign. This case is not handled. You can copy and paste this to SMath Studio:
Code:
solve(I.OUT_MAX*1.25≡η*1/2*N*I.PEAK_LIMIT(1-{(V.O+V.F)*N}/{V.I+(V.O+V.F)*N}),I.PEAK_LIMIT)
P.S. Hmm... this is my fault. I made a mistake when typing.
Edited by user 19 September 2016 19:44:57(UTC)  | Reason: Not specified
Russia ☭ forever
Offline tomtit
#272 Posted : 21 September 2016 21:47:39(UTC)
tomtit
Hi Uni,
I try my "example_that_works_in_5973.sm" time to time with new revisions of Smath.
Recently, behaviour changed again, this time returning vector of zeros(in 6103), instead of error messages(in 6096).
Is it possible to pass the nd[1] to maple() in a way how Smath displays it on the screen ? In this case it works.
It might be acceptable temporary solution for the issue to use function symb(x) that works like a macro, returning expanded x.
Edited by user 21 September 2016 21:57:06(UTC)  | Reason: Not specified
Offline uni
#273 Posted : 22 September 2016 02:55:59(UTC)
uni
The log file in the plugin folder shows details about what wrong here, I think I can improve function for support nested expressions.
Russia ☭ forever
#274 Posted : 22 September 2016 06:34:31(UTC)
Your proposal is short of instructions. The attached is 5346.
As instructed, it should work eternally as long as Smath can
access Maple. The red and gray modules may be combined.
Interesting to read your comment: works/does not work.
Maple coeffs NumDen.sm (24kb) downloaded 51 time(s).
#275 Posted : 22 September 2016 15:53:14(UTC)
Igor, my friend: that's all what you need => the companion codes.
If it does not work with your Smath version, some fix is needed.
Maple coeffs NumDen [Companion].sm (13kb) downloaded 47 time(s).
Offline frapuano
#276 Posted : 20 November 2016 16:22:26(UTC)
frapuano
Was thanked: 13 time(s) in 13 post(s)
Hi Uni
I am trying to use the Maple Wrapper and I am testing the example file you initially posted to explain how to use it.
The problem is that I have as a result on each example the sta ring "empty" . Probably this is due to the fact that I am using Smath Studio on windows 7 64 bit and the extension doesn't work on 64 bit OS.
Is there any way to workaround this issue?
Thanks in advance for your help and best regards
Franco
Offline alyles
#277 Posted : 21 November 2016 02:40:39(UTC)
alyles
United States
Franco,
Do you have an example of what you're trying to do? I use the Maple in Win7 x64 with no issue. I have had that error before and it's usually do to user error on my part.
Offline uni
#278 Posted : 21 November 2016 08:08:50(UTC)
uni
Originally Posted by: frapuano Go to Quoted Post
Hi Uni
Franco
I need more info:
- SMath Studio version;
- MapleWrapper version;
- contents of the log file after the calculations ({plugins}\32dfd679-8cfd-483a-b79a-19d5ea838750\x.x.x.x\log.txt).
Russia ☭ forever
Offline frapuano
#279 Posted : 21 November 2016 12:15:57(UTC)
frapuano
Hi Uni
herewith my answers.
- SMath Studio version -> 98.6096
log.txt (172kb) downloaded 35 time(s).
and an example of the output I receive
Franco
Offline uni
#280 Posted : 21 November 2016 13:56:59(UTC)
uni
Updated. Please do these steps again and show me log.txt. You can use "maple(sin(x))=" as a test example.
Russia ☭ forever
Guest (68)
