Offline TheWizEd
#1 Posted : 14 July 2010 22:02:00(UTC)
TheWizEd
United States
Was thanked: 19 time(s) in 13 post(s)
I was curious to see how units would be handled in matrices. So I tried a few things and was suprised how well it worked. See screen shot below.
Great job. Well thought out. Remeber everthing is calculated in SI units but comes out fine in US/Imperial units.
Ed
Offline TheWizEd
#2 Posted : 24 October 2010 19:11:53(UTC)
TheWizEd
United States
Another advantage of SMath over Mathcad is for matrix elements to have any units and the math is performed correctly. This matrix and multiplication of its elements is not possible in Mathcad.
Ed
Offline ralfsnell
#3 Posted : 30 August 2012 09:36:03(UTC)
ralfsnell
United States
How do these US units work?
If I take a simple force in kips multiplied by a moment arm in ft
I get result in J....then when I try to change units to kip ft
by adding kip, I get m kip...then when trying to get to kip ft
I get
kgm^2 kip'ft
________________
(s^2)kip'ft
Following from cut and paste....
el(F,1)*el(A,2)=225.97*{'kg*'m^2}/{'s^2*''kipft}@''kipft
Also, how do you get the units outside the matrix? I can only
put units immediately after the cell values.
Thanks for any responses.
Edited by user 30 August 2012 09:39:13(UTC)  | Reason: Not specified
#4 Posted : 30 August 2012 13:58:49(UTC)
Was thanked: 849 time(s) in 563 post(s)
Hi ralfsnell,
simply type in the right placeholder
Code:
'kip*'ft
regards,
w3b5urf3r
Edited by user 30 August 2012 14:00:48(UTC)  | Reason: Not specified
File Attachment(s):
U&M.sm (4kb) downloaded 13 time(s).
Best regards,
Davide
If you like my plugins please consider making a donation to SMath Studio
Offline ralfsnell
#5 Posted : 31 August 2012 18:04:14(UTC)
ralfsnell
United States
Thank you, was trying not to type but rather use the drop-down to insert units.
It appears the "*" was the missing element to that effort.
Appreciate your input and the attachment.
Originally Posted by: w3b5urf3r_reloaded Go to Quoted Post
Hi ralfsnell,
Code:
'kip*'ft
regards,
w3b5urf3r
Offline justhumm
#6 Posted : 19 January 2017 00:45:25(UTC)
justhumm
United States
When using a matrix with elements of a variety of units, is there a way to control the display of the resulting units (imperial instead of SI units)?
For instance, in the attached image:
k'(1,1) = A(in^2)*E(ksi)/L(in) = kip/inch, but results are in kg/s^2
k'(3,2) = 6 * E(ksi) * I(in^4) / L^2(in^2) = kip, but results are in kg*m/s^2
#7 Posted : 19 January 2017 01:57:29(UTC)
Hello justhumm Offline ,
You can try using
Code:
OutputUnitsSystem=Imperial
instead of
Code:
OutputUnitsSystem=Metric
in
Code:
%APPDATA%\Smath\settings.inf
(it is an experimental feature)
Best regards,
Davide
on 19/01/2017(UTC),  on 19/01/2017(UTC)
Offline justhumm
#8 Posted : 19 January 2017 02:51:58(UTC)
justhumm
United States
Davide Carpi:
Thanks for the response! It seems to be working.
Wishlist item:
It would be nice to have the ability to switch between feet and inches for the default imperial unit. :-)
#9 Posted : 19 January 2017 15:19:54(UTC)
You're welcome Good
Wishlist item:
You can join the [SS-1]
Best regards,
Davide
