SMath Studio Forum
Questions
percent symbol in math equations
Greetings, I am curious about the operation of the percent "%" symbol.
If I add, for example, 1+100%=..., it gives the warning "units don't match". I would expect it to return either 2 or 200%.
I only installed the program a few days ago, so maybe I am misunderstanding the operation of the % symbol. The program is very nice - just trying to figure out the details for input, etc.
Thanks!
Can't reproduce that with 0.98.6179. Make sure the % symbol is in blue italic (recognized as a unit). Type 1+100% TAB = The tabulator key is used to confirm the selection in the dynamic assistant. In SMath Studio % is nothing else than a representation of the number 0.01 |
Type X:=1.23456789*[in the place holder: insert % from drop down unit menu] check result X=0.0123456789
Thanks for the replies.
I believe my problem was replacing "Metric" with "Imperial" in the settings.inf file (OutputUnitsSystem variable). I was trying to force the output units to be Imperial, which was working, but apparently it has some effect on the use of the % symbol.
Anyway, I think changing to Imperial in the .inf is not technically a supported or approved method. So I changed my OutputUnitsSystem back to Metric and it works fine.
Thanks again.
Joined: 11/01/2018(UTC) Posts: 133 Location: Wisconsin Was thanked: 61 time(s) in 38 post(s)
Greetings! To the best of my knowledge, you should be able to redefine the 「%」 from 「dimensionless」 to a 「number」 of value: 0.01; keypress the following at the top of your worksheet: (NOTE: I currently have the settings.inf file modified to Imperial units 「OutputUnitsSystem=Imperial」 and % appears to behave as expected when it is redefined to 0.01) -Kenny Lemens, P.E. Edited by user 20 September 2022 21:24:26(UTC)
| Reason: Provided better clarity on "Note" (changes in darkred) |
Originally Posted by: RickH I would expect it to return either 2 or 200%.
SMath Studio Forum
Questions
