Offline Kriss
#1 Posted : 23 January 2017 17:54:20(UTC)
Kriss
Rank: Member
Собственно несколько вопросов, как:
1. Написать скрипт
2. Внутри тела скрипта использовать переменные Smath
3. Запускать скрипт по кнопке из exe представления Smath
Код на C# - примерный
Code:
using Kompas6API7;
using System.Runtime.InteropServices;
 try
                    Kompas6API7.IApplication kompas = (_Application)Marshal.GetActiveObject("KOMPAS.Application.7");
                    IKompasDocument doc =  kompas.App.Documents.Open("test", true, true);
                    IKompasDocument3D doc3D = kompas.App.ActiveDocument as IKompasDocument3D;
                    doc.Close(DocumentCloseOptions.kdDoNotSaveChanges);
                    doc3D.Close()
            catch (Exception)
                kompas = null;
kompas = null;
С уважением!
#2 Posted : 24 January 2017 13:46:37(UTC)
Was thanked: 1334 time(s) in 877 post(s)
Hello Kriss Offline ,
It might worth the effort to take a look at the code of existing plugins in our SVN. Some of them:
File import/export/read/save:
- ExcelFileType, XMCDFileType, XlsxImportExport,DataExchange;
Communication between applications:
- XLSXupdate (this is written in VB.NET), Maxima;
Database:
- SQLite;
Edited by user 24 January 2017 14:06:20(UTC)  | Reason: Not specified
Offline Kriss
#3 Posted : 24 January 2017 17:51:37(UTC)
Kriss
Rank: Member
Hello Davide Carpi Offline
Thanks for the reply.
I'll try workarounds,
if that happen I will try to put.
Offline Kriss
#4 Posted : 24 January 2017 18:34:47(UTC)
Kriss
Rank: Member
Arose fair question.
How to close the Preview window (*.exe file)
after clicking links
explanation
#5 Posted : 25 January 2017 12:44:01(UTC)
Originally Posted by: Kriss Go to Quoted Post
I guess it is the hyperlink region.
Alignment feature of hyperlinks is not available; I'll take a look on it when possible.
I'm not able to reproduce the 2nd issue, anyone else experienced this?
Edited by user 25 January 2017 12:45:46(UTC)  | Reason: Not specified
Offline Kriss
#6 Posted : 25 January 2017 18:02:24(UTC)
Kriss
Rank: Member
Hello Davide Carpi
I decided to use Smath Studio (Smath Viewer) as form to enter and calculate data.
The user then presses the Start button (as shown in the picture) and then start my program.
So I would like not to confuse the user and close the data entry form, ie Smath Viewer (executable file *.exe)
With best wishes
Edited by user 25 January 2017 18:06:20(UTC)  | Reason: Not specified
Offline Kriss
#7 Posted : 25 January 2017 18:19:06(UTC)
Kriss
Rank: Member
And another question
since You are a developer Hyperlink Region
It is possible to expand the possibilities of this Extensions:
Add command-line arguments when you start the program
For example:
"CalcMass.exe - ExchangeData.ods"
#8 Posted : 25 January 2017 19:25:13(UTC)
Hello Davide Carpi
With best wishes
Ah, ok! Good
Sometimes is not possible to close the viewer because internal exceptions, so I've thought about a bug.
I'll check if there is a safe way to kill the application within the hyperlink.
You can always add a text to ask the users that after clicking the link they can safely close the program.
For example:
You already can; right click on the region, choose "Flags..." from the context menu, and then add the arguments you need.
Edited by user 25 January 2017 19:58:04(UTC)  | Reason: typo
Offline Kriss
#9 Posted : 25 January 2017 19:49:07(UTC)
Kriss
Rank: Member
Thank you very much
Really works with the flags
Guest (2)
