SMath Studio Forum
Questions
how to know the name of the variable
how to know the name of the variable for example Count = 5
I can get the type of the variable GetType(Count)="number"
I can get the value as a string var2str(Count)="5"
I can even get a description of the variable description(Count)="TestDescription"
I need to get the variable name "Count" as a string
With best wishes
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Hello Kross,
You can't. If Count is defined (IsDefined(Count)=1), his value is replaced before being passed as argument in any function, hence the name cannot be retrieved. Why you need this? Maybe we can help you to find an alternative way to do the same or a similar task. |
Hello Davide! For my program StandardProject(see the topic in Extensions) For data exchange the user generates a matrix In the columns which 1 column - the name of the variable as a string 2 column - variable value as double 3 column - description as a string to simplify and reduce errors I was planning to write a function which input received the list of variables and the output was formed by the above matrix With best wishes! P.s. if you're interested as implemented watch the video https://yadi.sk/i/GT_K4LXm3EhvAqthe full set of videos https://yadi.sk/d/0aXk5NGQ3EhvUoEdited by user 27 February 2017 14:40:46(UTC)
Теоретически это можно сделать при помощи компонента Script, т.е. можно написать функцию на c#, которая возвращала бы нужную вам матрицу, перебрав все определения в документе. Практически же не знаю заработает это или нет, давно не пробовал компонент в работе. |
Originally Posted by: Kross I was planning to write a function which input received the list of variables and the output was formed by the above matrix unfortunately this won't work; once passed through the function even descriptions will be lost (because the values are passed on evaluation, inside the function nothing is known but the values). My suggestion is to create a function f(name,description,value) to create your matrix; function can be extended to 3 lists using vectorize() (or built directly to handle vectors). (or you can try to follow the hint given by uni). Edited by user 27 February 2017 18:39:36(UTC)
Thank you, Davide!
I also think that use the method proposed uni
To uni but I can't understand how to write scripts I propose to start with the basics
from a script to get Smath Studio any value while it turns out to show only variables in the debug panel (the output window)
К Вячеславу пока не могу понять как писать скрипты предлагаю начать с азов
как из скрипта получить в Smath Studio любое значение пока получается показать переменные только в панели отладки (окно вывода)
В скрипте есть доступ к объекту store и его методам. Насколько я помню, там есть метод AddDefinition(), с помощью которого можно добавить определение в текущий документ. То есть можно определить переменную, которой фактически нет в документе. Так работает функция include(), которая динамически добавляет определения в документ. Вы можете создать любое выражение и оно будет доступно ниже компонента Скрипт. Проблема в том, что нужно очень точно представлять результат, чтобы описать алгоритм в скрипте. Для этого лучше сначала написать функцию в виде дополнения, отладить её, а потом поместить в скрипт. Поэтому пользоваться этим инструментом полноценно пока могут лишь разработчики дополнений, которые знакомы с документацией. Я попробую набросать что-нибудь работающее. |
Спасибо за содействие!
Буду очень признателен.
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
Originally Posted by: uni Проблема в том, что нужно очень точно представлять результат, чтобы описать алгоритм в скрипте. Для этого лучше сначала написать функцию в виде дополнения, отладить её, а потом поместить в скрипт. Поэтому пользоваться этим инструментом полноценно пока могут лишь разработчики дополнений, которые знакомы с документацией. Я попробую набросать что-нибудь работающее.
Just for curiosity and without any insight into real plugin-coding: Isn't the programmatic representation of the expressions as required in the script region that what the "Expression -> terms" dialog in the Development tools produces? Is there a need to change the values for "List name" and "Array name"? |
There are several ways how to use Script region. Example 1. Code:try
TMatrix m = new TMatrix( new TNumber[ 1, 3 ] );
m.unit.SetValue( ( TNumber ) 1, new long[] { 0, 0 } );
m.unit.SetValue( ( TNumber ) 2, new long[] { 0, 1 } );
m.unit.SetValue( ( TNumber ) new TDouble( "\"Text\"" ), new long[] { 0, 2 } );
store.AddDefinition( "out", m.ToTerms(), new Term[0] );
catch ( Exception ex )
store.TraceData( ex.Message );
Joined: 01/08/2010(UTC) Posts: 115 Location: Rome Was thanked: 13 time(s) in 13 post(s)
Originally Posted by: uni There are several ways how to use Script region. Example 1. Code:try
...it is quite sad/frustrating not to understand better its usage ...just to organize to give it a try. Franco
To uni
it's great how do I output the variable in the field Smath Studio - understand Question 1. how to get a specific variable from Smath Studio 2. is it possible to imagine a script as a function Smath Studio for the subsequent call as a "normal" function Smath Studio
Перевод это отлично как вывести переменную в поле Smath Studio - понял Вопрос 1. как получить конкретную переменную из Smath Studio 2. можно ли скрипт представить в виде функции Smath Studio для последующего вызова как обычной функции Smath Studio
Example 2. How to get definition by name Code:try
string varname = "a";
// System.Collections.Generic пока не подключена, поэтому используем полное имя класса.
// Переменная store не содержит публичного метода или свойства для доступа к коллекции определений,
// поэтому создадим список "вручную". Со списком работать удобнее, чем с массивом.
System.Collections.Generic.List<Definition> list = new System.Collections.Generic.List<Definition>();
for ( int n = 0; n < store.Count; n++ ) list.Add( store[ n ] );
// Функция условия для поиска определения.
Predicate< Definition > cond = delegate( Definition x )
// Если имя определения (переменной) равно varname.
return x.Name.Equals( varname );
// Метод Find ищет первый элемент, который удовлетворяет условию.
Definition def = list.Find( cond );
// Если элемент найден, то что-нибудь делаем.
store.TraceData( varname + ( def != null ? " " : " not " ) + "found" );
if ( def != null )
TMatrix m = new TMatrix( new TNumber[ 2, 3 ] );
m.unit.SetValue( ( TNumber ) new TDouble( "\"name\"" ), new long[] { 0, 0 } );
m.unit.SetValue( ( TNumber ) new TDouble( "\"descr\"" ), new long[] { 0, 1 } );
m.unit.SetValue( ( TNumber ) new TDouble( "\"value\"" ), new long[] { 0, 2 } );
m.unit.SetValue( ( TNumber ) new TDouble( "\"" + def.Name + "\"" ), new long[] { 1, 0 } );
m.unit.SetValue( ( TNumber ) new TDouble( "\"" + def.Description + "\"" ), new long[] { 1, 1 } );
TNumber value = SMath.Math.Numeric.Expression.Calculate( def.Result, store );
m.unit.SetValue( value, new long[] { 1, 2 } );
Definition res = new Definition( "out", m.ToTerms(), new Term[ 0 ] );
store.AddDefinition( res );
Перевод это отлично как вывести переменную в поле Smath Studio - понял Вопрос 1. как получить конкретную переменную из Smath Studio 2. можно ли скрипт представить в виде функции Smath Studio для последующего вызова как обычной функции Smath Studio 2. Как функцию представить нельзя. П.С. Теоретически можно написать дополнение, в котором можно использовать написанную функцию и потом вызывать её многократно как стороннюю. Я бы мог даже добавить кнопку в компоненте Скрипт, по которой формировалась сборка, но это всё сложно и целая эпопея. Edited by user 01 March 2017 13:21:41(UTC)
То uni Возникли проблемы при использовании Лист.exe файл - исполняемый 1. Не обновляется поле из out переменной (выходной) 2. При перемещения тела скрипта в Область и последующим скрытием Области при запуске Лист.exe файл - появляется сообщение - No 'Tech.CodeGenaration.dll' found in 'Лист'.
here's what you need to in the end Edited by moderator 01 March 2017 15:29:58(UTC)
Я не знаю как пересчитать лист в exe версии. Для работы нужно скопировать в папку с exe-файлом следующие сборки:
Из папки с плагином (%user%\Application Data\SMath\extensions\plugins\20ad815b-bc5e-487d-9258-57fde2ac6de8\0.1.5997.41919\):
IronPython.dll IronPython.Modules.dll Microsoft.Dynamic.dll Microsoft.Scripting.dll Microsoft.Scripting.Core.dll Microsoft.Scripting.Debugging.dll Microsoft.Scripting.ExtensionAttribute.dll Tech.CodeGeneration.dll
Из места установки программы:
SMath.Controls.dll SMath.Manager.dll SMath.Math.Numeric.dll SMath.Math.Symbolic.dll
Вообще, вам лучше научиться писать плагины самому, тогда не нужно будет искать других путей. Ваша задача не решаема стандартными средствами SMath Studio. |
Все ясно, Спасибо!
Буду разбираться с написанием плагина!
SMath Studio Forum
Questions
