2 Pages<12
#21 Posted : 01 March 2017 21:59:41(UTC)
Forum Var name.sm (14kb) downloaded 30 time(s).
Offline uni
#22 Posted : 05 March 2017 18:41:32(UTC)
uni
Вот так можно решить задачу при помощи компонента Скрипт.
Code:
var defs = Enumerable.Range( 0, store.Count ).Select( n => store[n] ).ToList();
var args = ( Entry.Create( terms ) ).Items.ToList();
var vars = args.Take(4).Select( x => new Entry( "\"" + x.Text + "\"" ) ).ToList();
var vals = args.Take(4).ToList();
var desc = args.Take(4)
    .Select( x => defs.Find( d => d.Name.Equals( x.Text ) ).Description )
    .Select( x => new Entry( "\"" + x + "\"" ) ).ToList();
var rows = new Entry( "4" );
var cols = new Entry( "3" );
var mat = new Entry( "mat", TermType.Function, new Entry[]
    vars[0], vals[0], desc[0],
    vars[1], vals[1], desc[1],
    vars[2], vals[2], desc[2],
    vars[3], vals[3], desc[3],
    rows, cols
store.AddDefinition( args[4].Text, new Term[0], mat );
Script. Kross example 1.sm (7kb) downloaded 13 time(s).
Script. Kross example 1.pdf (19kb) downloaded 15 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
on 06/03/2017(UTC)
#23 Posted : 05 March 2017 20:11:20(UTC)
Is there access to some list of definitions in the sheet? The script example seems to reqire explicit specification, which variables are to be processed. Could I just ask to export everything (excluding pre-defined names)?
If specification of the variables is acceptable, then the matrix can be created relying on math regions only.
export.sm (7kb) downloaded 12 time(s).
2017-03-05 18_00_56-SMath Studio 0.98.6179 - [Script.%20Kross%20example%201.sm_].png
on 05/03/2017(UTC)
Offline uni
#24 Posted : 05 March 2017 20:22:28(UTC)
uni
Yes, the first line do it.
Code:
This means: get all enabled definitions.
How to check this.
Code:
    .ToList();
defs.ForEach( d => store.TraceData( d.ToString() ) );
Russia ☭ forever
on 05/03/2017(UTC)
#25 Posted : 05 March 2017 20:35:01(UTC)
I just downloaded the script region and pasted the code above into it and set language to C#.
This gives the error message in the output window:
Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
(system can't find the file)
SMath Studio: SMath Studio Desktop 0.98.6179.21440, portable, x86
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Windows 7 Professional , x64)
Screen: 1920x1080 px, 96x96 dpi
Localization: separator=<semicolon>; decimal symbol=<comma>; system decimal symbol=<comma>; language=GER
Frameworks: CLR 2.0.50727.5485
installed versions:
v2.0.50727 2.0.50727.5420 SP2
v3.0 3.0.30729.5420 SP2
v3.5 3.5.30729.5420 SP1
v4
Client 4.6.01055
Full 4.6.01055
v4.0
Client 4.0.0.0
Offline uni
#26 Posted : 05 March 2017 20:42:56(UTC)
uni
Try to remove it manually and update again (20ad815b-bc5e-487d-9258-57fde2ac6de8).
For 0.98.6179 last version is 0.1.6273.2204.
Edited by user 05 March 2017 20:48:13(UTC)  | Reason: Not specified
Russia ☭ forever
#27 Posted : 05 March 2017 21:36:49(UTC)
I deleted the dir and re-installed from extension manager (I did this just some hours ago, thus if the online gallery didn't change, then this didn't change anything locally).
There is a file LinqBridge.dll, yet the log file says
05.03.2017 19:30:58 [INFO ] Script Region, version 0.1.6273.2204, Sonntag, 5. März 2017 01:13:28
05.03.2017 19:31:28 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
It says that LinqBridge or a dependence of it was not found.
Same message in the output window.
Offline uni
#28 Posted : 05 March 2017 21:51:30(UTC)
uni
I think I found the problem. Plugin updated, please try again.
Russia ☭ forever
#29 Posted : 05 March 2017 22:08:45(UTC)
Sorry, didn't solve the problem. This is what the log says:
05.03.2017 20:05:57 [INFO ] Script Region, version 0.1.6273.19487, Sonntag, 5. März 2017 10:49:34
05.03.2017 20:06:20 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
Offline uni
#30 Posted : 05 March 2017 22:15:03(UTC)
uni
I forgot to replace Tech.CodeGeneration.dll. Plugin updated, try again.
Edited by user 05 March 2017 22:24:19(UTC)  | Reason: Not specified
Russia ☭ forever
#31 Posted : 05 March 2017 22:34:13(UTC)
05.03.2017 20:31:31 [INFO ] Script Region, version 0.1.6273.20457, Sonntag, 5. März 2017 11:21:54
05.03.2017 20:31:54 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
Offline uni
#32 Posted : 06 March 2017 07:37:04(UTC)
uni
Only portable version not working or both?
Russia ☭ forever
#33 Posted : 06 March 2017 10:23:51(UTC)
Good point, installer version works. But installer version is a bad place for experiments.
Offline uni
#34 Posted : 06 March 2017 10:43:08(UTC)
uni
Ok, I need portable version. How I can get it? This link not working for me.
Russia ☭ forever
#35 Posted : 06 March 2017 10:56:55(UTC)
Currently the link is broken. Unpacking the linux version to some directory and placing an empty file "portable.version" in the install dir is a workaround (or better: the official way).
Offline uni
#36 Posted : 06 March 2017 12:21:52(UTC)
uni
Well, I reproduced the problem. It is much harder to fix than I thought before (I don't know why it is happening for portable version).
Russia ☭ forever
Offline uni
#37 Posted : 06 March 2017 15:01:52(UTC)
uni
Сontinue in this topic.
Russia ☭ forever
#38 Posted : 17 March 2017 18:42:30(UTC)
Something close to your request (input must be provided with strings, output is automated and issues reported in trace window)
name+value+description.sm (8kb) downloaded 23 time(s).
Edited by user 17 March 2017 18:51:23(UTC)  | Reason: Not specified
Guest (2)
2 Pages<12
