SMath Studio Forum
Questions
Numerical Integration of Data Set
Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
Is there an easy way to integrate a data set using the trapezoid rule, like the "trapz" function in matlab? Also is there an easy way to find the centroid of this area? I've attached a sample data set. integration array.sm (4kb) downloaded 48 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,649 Location: Italy Was thanked: 1332 time(s) in 876 post(s)
That's perfect!! Thanks for your help!
or I can add original "trapz" function to the matlab plugin if you really need this. |
Thanks but this is more than sufficient for my needs.
Regards.
Ernesto, Your data set is not impressive. As is: it represents no physical phenomenon. The way I see it is otherwise ... it looks the linear junctions can only represent derivatives of quadratic. It suggests a polynomial fit [offered]. Is it a piece of wood ? the fence around the yard ? Jean integration array [option].sm (23kb) downloaded 40 time(s).
@Jean
It is horizontal soil pressure vs depth
Originally Posted by: Ernesto @Jean
It is horizontal soil pressure vs depth Thanks Ernesto, interesting. You can complete and export your project, in red at the end of the WS. Jean Polynomial fit QUARTIC Option.sm (27kb) downloaded 42 time(s).
SMath Studio Forum
Questions
