I have been reading the tutorial on graphing by Dr. G E Urroz. On page 20 there is a formula presented by Dr. Omorjan reproduced below plotG x , y , char, size, color:=n length x plot augment x 1 , y 1 , char, size, color for i 2 ..n plot stack plot, augment x i , y i , char, size, color i 2 ..n plot
Would someone please post the keystroke (function)needed to make this formula/program.
I have tried a bunch of functions like row vector, matrix etc but can not recreate the vertical line that makes the program effective. Thanks Joe
Hello Joe, Just see some of the many examples posted by Jean Giraud. You will find there the functions you are looking for. BTW, you need the line environment (keystroke ]) in order to make a multiline function Regards, Radovan Edited by user 25 March 2017 21:36:13(UTC)
If you need lot of points, you need a more efficient algorithm. (".",6,"#808080" ... in this definition, "#808080" is any coded web color. Jean Random Fill Range PDF.sm (40kb) downloaded 38 time(s).
