The code 3D Smath 6179 does not correspond to Smath in *PDF [tutor]. Observe the code inversion augment(x,y,z) <==> augment(x,z,y). Bugs 3D.sm (17kb) downloaded 28 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Originally Posted by: Jean Giraud Hello Jean, I can't see differences in behavior, except that in the code you linked above y and z are swapped Edited by user 06 June 2017 21:58:41(UTC)
| Reason: marked as SOLVED (not a bug) |
Hello Davide,
Always there ! Yes, the 3D plot code are in reverse order. Cheers, have a good day ... Jean
