Joined: 02/06/2017(UTC) Posts: 18 Location: Stoke on Trent
Hi All, I'm trying to create an input table for a worksheet I'm working on. It's probably a bit of a newbie question but I'm new to SMath (and matrices !) so any help would be appreciated. I want to perform calculations on the data in matrix BODY. I've done this in BODY2 as a workaround but I'd like to find a way of doing it so I don't have to edit BODY2 everytime I add or delete a row. Any help / guidance would be appreciated Peter TableRegion_Test.sm (11kb) downloaded 13 time(s). |
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Hello Peter, You can use a simple loop, like this: TableRegion_Test.sm (11kb) downloaded 23 time(s).Edited by user 08 June 2017 01:28:42(UTC)
| Reason: marked as SOLVED |
Thank you Davide As I thought the answer was simple but I just couldn't see it. I've been using Mathcad for a few years but have recently discovered SMath and am blown away by it. Thanks again Peter |
Peter J Francis
Hello Peter ! Matrix maths is not same as "Matrix table". I don't use much this feature for collecting data, but can demonstrate how to fill. By same token, the attached "matrix Treasury might help in real "Matrix maths". Welcome to Smath Community Jean TableRegion_Test jmG.sm (23kb) downloaded 21 time(s). Utilities Matrix Treasury Copy.sm (337kb) downloaded 27 time(s).
