I'm not sure but I think it's a bug. I tried to use the while function and when I want to converge a number to a constant there is no problem. But when I want to converge two numbers to each other like below, the program stops working.
Example:
x:=0 a:=20-2*x b:=15-x while a>b x:=x+1
This is not a bug. Second line (a:=20-2*x) program calculate as a:=20, becouse you've define x:=0; third line has similar result, so your condition in while loop is allways true. Here is solution: (download an example)Edited by user 17 February 2009 06:02:01(UTC)
