3 Pages<123>
Offline oscampo
#21 Posted : 28 August 2017 20:28:47(UTC)
oscampo
Colombia
Originally Posted by: Davide Carpi Go to Quoted Post
However I've edited the link, now it downloads the file, whatever is your favorite browser. Whistle
Thanks Davide!!
#22 Posted : 29 August 2017 02:58:29(UTC)
Thanks Davide for the WS.
"assume" is often needed as well as "real".
The most common is "allvalues". It expands
the more general RootOf.
#23 Posted : 29 August 2017 13:30:28(UTC)
#24 Posted : 29 August 2017 14:13:02(UTC)
Offline 007.000
#25 Posted : 05 July 2018 12:00:06(UTC)
007.000
Rank: Member
United States
I'm still trying to get the hand of this software. I'm an e.e. undergraduate and would like to be able to perform the something like the mathcad at the end of this post. I did try to input a similar syntax but I'm too much of a noob to work it. Can anyone shed some light on this for me?
The post shows a trasfer function solved for the poles and zeros... It looks like you have to know how many poles and zeros to solve for before getting going. That would require putting the transfer function in standard form I'm somewhat sure.
https://electronics.stac...f-transfer-function?rq=1
#26 Posted : 05 July 2018 14:37:52(UTC)
All documents attached are in Smath 6179, should work same imore recent version(s).
The Smath/Maple companions of this year [2018] work a bit different than Mathcad 11 [2003].
At the end, all attached documents work for me Smath 6179 same as my former Mathcad 11.
Inst_PID [ODE].sm (25kb) downloaded 53 time(s).
Inst_PID Discrete State Systems.sm (26kb) downloaded 52 time(s).
Inst_PID DynSys.sm (15kb) downloaded 49 time(s).
Inst_PID [PI, PID].sm (72kb) downloaded 49 time(s).
Inst_PID [P, PD].sm (107kb) downloaded 46 time(s).
Inst_PID Feedback Attenuator.sm (44kb) downloaded 51 time(s).
Inst_PID [MCD Model].sm (178kb) downloaded 44 time(s).
Inst_TurboGen Smath.sm (107kb) downloaded 46 time(s).
ODE_Laplace Read First.sm (28kb) downloaded 51 time(s).
Inst_TurboGen Signum.sm (92kb) downloaded 48 time(s).
Inst_PID Discrete Schema.sm (167kb) downloaded 49 time(s).
ODE_Laplace 1rst [Type 1].sm (25kb) downloaded 53 time(s).
Inst_XFR 2nd [XFR nth].sm (35kb) downloaded 52 time(s).
ODE_Laplace 1rst [Type 2].sm (23kb) downloaded 47 time(s).
Inst_PID DynSys_v01 (1).sm (236kb) downloaded 54 time(s).
ODE_Laplace 2nd [Type 3].sm (34kb) downloaded 50 time(s).
ODE Laplace Kinetic Reaction.sm (94kb) downloaded 53 time(s).
Offline alyles
#27 Posted : 05 July 2018 17:11:33(UTC)
alyles
United States
Here's an example of how one might attack it.
Page1.sm (45kb) downloaded 94 time(s).
Offline oscampo
#28 Posted : 05 July 2018 18:58:56(UTC)
oscampo
Colombia
Bravo! Alyles, simple and beautiful!!
#29 Posted : 05 July 2018 19:04:44(UTC)
You may attack for an export solution.
Offline Basile
#30 Posted : 07 July 2018 02:56:39(UTC)
Basile
Jean,
What why the invlaplace I get a dot?
Inverse Laplace-1.sm (5kb) downloaded 41 time(s).
Basile
#31 Posted : 07 July 2018 03:30:07(UTC)
Originally Posted by: Basile Go to Quoted Post
Jean,
Basile, mon ami, you need a new pair of glasses !
Just code as the snippet, it will gladly work for Basile.
Offline Basile
#32 Posted : 07 July 2018 17:57:01(UTC)
Basile
Jean,
Until I get my new pair, I see that a dot appears after the F(s) when I type a comma.
Any diagnosis?
Inverse Laplace-2.sm (5kb) downloaded 34 time(s).
Basile
#33 Posted : 07 July 2018 20:28:49(UTC)
Jean,
Any diagnosis?
Check from "Options" if you can fix .
Offline Basile
#34 Posted : 13 July 2018 02:05:19(UTC)
Basile
Jean,
Can you be more specific?
Basile
#35 Posted : 13 July 2018 05:15:48(UTC)
Jean,
Basile
From the menu tool bar up top work sheet:
Tools => Options => Interface => Arguments separator [period, coma, semicolon]
Offline Basile
#36 Posted : 13 July 2018 15:21:09(UTC)
Basile
My glasses arrived!
Thank you,
Basile
Edited by user 13 July 2018 15:23:29(UTC)  | Reason: Not specified
Offline 007.000
#37 Posted : 24 August 2018 02:53:31(UTC)
007.000
Rank: Member
United States
After doing my best to incorporate sMath into my University workload for the past 6 months. From my magnetism class to my analog circuits class here at the University of California at Santa Cruz but it has been my experience that for every line of code I write that I generate many more while trying which are unproductive. I think the efforts made on this program are exemplary and I've donated $10 but I think unfortunately I will not be able to continue with it due to the learning curve being so steep.
People have done some amazing things with it that I can't even begin to follow but I haven't been as successful. Perhaps as I become more competent I might be more successful but for now I think I will unfortunately have to hang up my hat gentlemen... I bid you a respectful adieu for the time being kind Sirs...
hw 2.6.sm (131kb) downloaded 40 time(s). open loop gain from closed loop gain 2.sm (40kb) downloaded 29 time(s).
magnetism.zip (5,393kb) downloaded 48 time(s).
#38 Posted : 24 August 2018 06:30:05(UTC)
I have doctored few things in these two documents.
hw 2.6.sm (134kb) downloaded 50 time(s).
open loop gain from closed loop gain 2.sm (49kb) downloaded 48 time(s).
Offline Razonar
#39 Posted : 21 September 2018 12:23:31(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Originally Posted by: oscampo Go to Quoted Post
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Oscar Campo
Hi. Enjoyed & Improved. Six years later.
InvLaplace2.sm (94kb) downloaded 55 time(s).
Edited by user 21 September 2018 12:32:40(UTC)  | Reason: Not specified
#40 Posted : 21 September 2018 17:43:32(UTC)
Originally Posted by: Razonar Go to Quoted Post
Enjoyed
Thanks Alvaro for your dedication,
Does syntax error 6179, but does not to where it complains.
Don't worry, OK like this.
The 2nd example is lot more involved, correct [sanity MCD].
InvLaplace2 Otherwise.sm (28kb) downloaded 44 time(s).
3 Pages<123>
